How to remove agitator
I would try to get clothes out, even if destroyed first. Otherwise,
there is a plastic cover cap on the top of the agitator. remove
by unscrewing or prying off. Hold down nut is exposed and remove
carefully, gently and with a ballanced pry up from underneath to raise agitator.
Posted on Dec 22, 2014
SOURCE: Remove the agitator
The agitator is actually pressed on without mechanical fasteners . Grab the bottom of the agitator firmly on each side. Pull up with a quick, hard **** (careful not to hit your face). If this does not work, wrap a belt under the agitator. Grab the belt firmly and pull up with a quick, hard ****.
Posted on Dec 25, 2008
SOURCE: agitator removal to remove clothes stuck beneath
for the basic top loader there should be a cap on the top of the agitator you can pop off with a flat screw driver and then use a ratchet with an extension to get to the nut holding the agitator on, 1\2 inch or 9\16 socket, i think.
Posted on Dec 12, 2009
SOURCE: Is there a way to remove the agitator? I have a
Jdangullet --
Yes, the agitator assembly can be removed. The WPRE6100G parts diagram is available at: [http://www.geappliances.com/] The top plastic portion of the agitator can be removed to access the screw [SCR 1/4-20 MCH HXW 5/8 S] securing the coupling assembly. If you have questions, write back. -- SWT
Posted on Aug 22, 2010
SOURCE: My clothes are stuck under
i believe this unit has a fabric softner on top of the agitator ... the cap should come off and there is a 7/16 or 1/2 inch head that will have to come off then the agitator pulls straight up... if this one does not have a cap on top of agitator grab from bottom and pull straight up sometimes it requires some muscle..... this was a common problem with g.e. units... i am a owner of a appliance /heating and air company out of texas see this alot...... good luck to you a/c and heating unlimited
Posted on Dec 31, 2010
Aug 23, 2014 | GE WBSR3140DW Top Load Washer
Mar 09, 2011 | Estate TAWS800JQ Top Load Washer
Jan 29, 2010 | Whirlpool Washing Machines
Jan 11, 2010 | Kenmore 98702 Stacked Washer/Dryer
Jan 08, 2009 | Washing Machines
Jan 04, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Oct 28, 2008 | Whirlpool LTE5243D Top Load Stacked...
Oct 18, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Jul 01, 2008 | Kenmore 22422 Top Load Washer
Dec 14, 2007 | Frigidaire FWS833A Top Load Washer
268 people viewed this question
