Green light comes on flashes 10 times then goes to standby red which flashes 10 times and keeps and keeps repeating this until the TV is switched off. Keep trying this same thing happens
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
SOURCE: Sony Wega 40" TV will not turn on, standby light blinks 6 times repeatedly
Hello,For model KV-40XBR800,
Pls check following area.
Low HV Shutdown:
On the D Board.
Check IC8004/pin 7 should be 7.4v.
Check IC8006/pin 2 should be 2.5v if lower will trigger shutdown by causing pin 1 to turn on.
Check IC8006/pin 3 reference voltage 2.2v.
IC8006/pin 1 normally at 0v. If high
turns D5007 ON which turns the latch circuit Q6532,
Q6530, and Q6527 ON and turns the AC relay RY6501 OFF.
And NOTE: 6 blinks also can be Low B+ protection.
Unregulated 7.5 v from the power supply to 5v reg IC504 on the A Board. 5v to M Board Q2314
to CPU IC2300/pin 43. If 5v missing set will shutdown with 6 blinks.
Good Luck
Dals123
SOURCE: Sony FD Trinitron WEGA KV-24FS100 24" TV On/Off problems
I think I have the solution for you. I have the same tv and it does the
same thing when you turn on the power button on the remote when the tv
turns on you hear a click then the red light flashes about 5 to 6 times
then the tv comes on. on the remote there should be two buttons on top
of the remote one says power and the other one says system hit the
power button to turn on the tv when you hear the click and see the red
light flashing then hit the system button which will turn off the tv
then hit the power button again and it will turn the tv on without the
red light flashing it should work
SOURCE: STANDBY LIGH BLINKING 9 times...
I have a Sony SRS BBE Trinitron (WEGA). The last few days when I tried to turn it on using the remote the Red Light would go on but the TV did not turn on. I would have to press the power button again to turn it on.. I tought the remote battery was just low.
Today when I tried to turn it on nothing is happening and the Red Light is blinking 9 times ??? I tried to unplug it and try it again, still does the same thing ???
We need help...
Lori Nall
SOURCE: Sony FD Trinitron WEGA KV-32HS500...red standby light blinks 6 ti
I
have over 10 years experience in electronic tech
support.
I
know this isn't what you want to hear, but the problem you've
described can't be fixed with troubleshooting.
Your TV
will have to be repaired. There is a part that has developed a defect
and needs to be replaced. If you're still in warranty, the TV will be
repaired at no charge to you. The warranty would likely be at least
one year from the date of purchase from the manufacturer. If you
purchased an extended service
plan
they will repair the TV at no charge as well.
If the TV is no
longer in warranty, it will likely cost a minimum of $150 parts and
labor. This is assuming that you only need one circuit
board
or small part. If the problem is more than one of the circuit boards,
the price of repair could go much higher.
I hope I've provided
you useful assistance and that this information allows you to make an
informed decision as to how to proceed from here. Please be sure to
vote on my response. I hope I've earned a good rating from you
today.
Please let me know if I can be of further assistance.
SOURCE: KV-HX32 SONY WEGA TV
The hight voltage transformer it dead.The FBT(The flyback transformer is dead)The block of plastic with the red wire with a cap hook to the CRT(the tv tube).
Testimonial: "Thank you so much"
If your Sony Wega will not turn on, the front green light blinks, you hear a faint whirring sound and the green light turns red and flashes, it probably means the lamp inside the set is no longer working. If you noticed the screen beginning to dim in the preceding days or weeks, this most likely is the cause.
If the green light flashes and the picture comes on momentarily but then goes off, and the green button flashes until the set restarts, then the seal around the lamp mount is loose and needs to be refitted.
If the picture on your Grand Wega cuts in and out and the green standby light flashes, both of the set's STKs need to be replaced. STKs are small chips on your television's circuit boards and are identifiable by their labels. The specific STKs used in your Grand Wega TV will be identifiable by the numbered labels on top of the STKs.
When you plug in your Sony Wega and hear a loud popping sound, it's probably caused by a defect in the high-voltage circuit. Let the professionals take care of this one.
If, after turning on your Sony Wega, you can hear your set but the screen is black, you most likely need to replace your projection lamp.
