Question about Tylo Deluxe 11kW Sauna Heater, w/ TS30-01 wall controls & rocks
Wiring diagram for tylo ts30 single phase
Wiring diagram is not labeled to identify the neutral connections so show me one that does as I am loosing my patience
deton8 von Splosion
  • 3,340 Answers
Swell... Anonamous,
Take your "patience" issues to the
company (Tylo)
where they might be considered constructive...
It's just a 'TUDE here ...!!
(not helpful)
Control Panel TS (USA)
Carnac the Magnificent
Posted on Mar 03, 2017
Where can i obtain a wiring diagram
A one phase 3 wire system has a center tap. Two hots and a neutral. Typical 120/240 volts.
A three phase 4 wire system has Three hots in a Y or Delta. The Y system has three hots and the neutral comes from the center of the Y, this is the neutral and grounded conductor, 120 volts from hot to ground and 208 volts hot to hot. In a 3 phase system the voltage is not doubled hot to hot as in a single phase system because the hots are 120 degrees phased from each other and the square root of 3 is the factor, multiply the 120 volts by 1.73 to get 208 volts hot to hot. Multiply 208 by the reciprocal of 1.73 and get 120 volts. Your exact application is not given so it is not known. A delta system is a triangle and the angle of each triangle is a hot wire, one angle would be grounded or the center tap of one of the sides of the triangle. Y is the configuration of the windings of the alternator or transformer and Delta is the configuration as a triangle of the windings of the alternator or transformer where the power supply is.
With a three phase home service, you can only connect two hots from your single phase generator, and the neutral. One of the house's hot does not get connected and any three phase loads in the house should be switched off and kept from energyzing or a circuit breaker or fuse serving that 3 phase load may trip.
Only one power supply can be connected at a time. The power company power must not be connected at all while using an alternate power supply unless your power supply has means to synchronize the alternating cycle.
It is adviced that the loads be kept within 10% of their rated voltage, especially motors.
May 04, 2015 | Heating & Cooling
Essick air compressor wiring diagram
telepathy do not work that hot as in hollywood movies...
you need to provide a model or at least if this is three phase or single phase...
single phase is easy, you have cord with three wires, earth, active and neutral.
you need to open connection box on your compressor and you will find three wires there terminating in junction box, earth connect to earth (usually green or green with yellow stripes), then you have your neutral (usually brown or black) and active (usually blue or red), connect them, do not put cover on yet, plug cable into the power point and switch on/off power. check if motor is rotating in correct direction, if fuses are not blown... if motor is rotating in wrong direction - switch power wire with neutral wire, it just meant that you wired it in reverse...
do not need diagram for that...
do not forget to give some points...
Dec 30, 2013 | Park Tool Inf1 - Shop Inflator For Use...
Magnetek m56j wiring schematic
Wiring diagram will show on label on side of pump.
High voltage and Low voltage.
The rating has to be single-phase and not 3-phase, otherwise motor will not rotate as expected.
Take in-focus photo of label using macro setting on digital camera, and post photo on flickr, and then add a comment with link to that photo.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 08, 2012 | Pool & Spa
What happen with a wrong connection on a single phase 2hp sp motor
I'm not sure which motor you have - the heading shows a 1HP type - yet you talk about a 2HP type. Anyway, the label on the motor should have a wiring diagram. You must have a label on the motor to know how to wire. It may have two diagrams - one designated as "high voltage" and the other "low voltage". Check the label for voltage.. it likely says "120/240 volts". The 120 uses the low volts diagram and the 240 uses the high volt diagram. If the motor has terminals L1 and L2, these will most likely be the point of connection for power - regardless if it 120 or 240, unless the label states otherwise. Unless the neutral connection is specified on the label, it does not matter which L1 or L2 you connect it to.
The other terminals will be required to be connected properly. Motors use these connections or jumpers to set options such as voltage, direction of rotation, speed(s), etc. An incorrect setting here can cause unexpected results as far as speed and rotation, or catastrophic results if you supply this motor with 240 volts but set the jumper for 120 volts.
Here's a link to their catalog with telephone numbers for you to review.
Apr 26, 2012 | A O Smith Motors A O Smith 1hp 115/230v Ur...
1/3 Hp 115 volt 24 year old motor 40 amps. single Phase. is this for 110 volt Plug in to wall.It also 3 wires , Orange,Red, White, were do i hook these up to on a 110 Plug. Can you Please help.
You looked at nameplate on motor to get the rating information?
Rating plate may also have small wiring diagram.
I was looking at AO Smith single-phase 2-speed pool pump motors yesterday.
The rating plates show wiring.
Open following link:
http://waterheatertimer.org/images/AO-smith-rating-label-500.jpg
Notice the image shows the words: Brown White Line Line.
Brown and white are wire colors. Line means 'power' from breaker box.
240V will have two Line wires, L1 and L2. 115Volt will have Line or L1 and N or Neutral.
Look at your rating plate and then add a comment with clear description of what appears on rating plate, or include in-focus photo. Put your camera in macro to take close-ups.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Your wall outlet has 2 plug-in slots. One is wider that the other.
'Line' will refer to Hot wire from breaker which corresponds to smaller slot on outlet.
'N' or 'Neutral' is neutral wire from breaker box which corresponds to wider slot on outlet.
Apr 30, 2011 | Electrical Supplies
How can i get single phase power from my 3 phase generator
I have not wire this myself
Wiki says under heading of single-phase:
http://en.wikipedia.org/wiki/Three-phase_electric_power
Single-phase loads may be connected to a three-phase system in two ways. A load may be connected across two of the three phase conductors or a load can be connected from a live phase conductor to the system neutral. Single-phase loads should be distributed evenly between the phases of the three-phase system for efficient use of the supply transformer and supply conductors. Where the line-to-neutral voltage is a standard utilization voltage (for example in a 230 V/400 V system), individual single-phase utility customers or loads may each be connected to a different phase of the supply. Where the line-to-neutral voltage is not a common utilization voltage, for example in a 347/600 V system, single-phase loads must be supplied by individual step-down transformers.
So it sounds like you take 2 legs of the 3-phase.
or
Take one leg of the 3-phase and connect to neutral ... neutral could be a ground rod.
I would put a meter on that circuit before hooking up my power saw.
Nov 17, 2010 | Electrical Supplies
Wiring diagram for electricmotor with capacitor
On most motors the wires with the tabs are connected to the capacitor (usually brown). White wire is neutral and color wires are speeds.
May 09, 2010 | Heating & Cooling
My name is Andy Smith i am Electrical Engineer on
Hi Andy, I am Kelly and wish to at least make an attempt to help you out. I have done quite a bit of research and like you have come up with little nothing positive.
You may have to buy your own 3 phase 24DC controlled contactor and control that with a yet another relay.
At this point you may want to call Tylo direct or email them and explain your needs to see if they can help you.
Page 8 of their installtion manual shows several 3 Phase connections
http://superiorsaunas.com/storeimages/products/heaters/tylo/tylo_elec_install.pdf
Tylo contct info:
TYLö AB, Svarvaregatan 6, S-30250 Halmstad, Sweden.
Tel +46 35 10 00 80, Fax +46 35 102580. E-mail: [email protected] Internet: www.tylo.se
Here is the controller you may need with a 5 meter capillary tube. it does not say if it is 3 Phase and it is mecanical.
Seriously I would contact Typo directly via the contact info above and solve your problem quickly.
The link.... for the TS-30-012
http://www.saunahaus.com/Sauna-Control-Units/Sauna-control-TYLOe/TYLOe-Control-panel-TS-30-012::218.html
I do wish you the best.
Jan 26, 2010 | Tylo TS30-01 Control Panel
I am Replacing a pump motor and I'm not sure of the connections
high speed phase neutral should go to High speed {phase} neutral low speed {phase} should go to neutral .....Low speed and high speed {phase} need not be connected
Jun 15, 2009 | Waterway 5 Hp 230 Volt 2 Speed Side...
Tylo Deluxe 11kW Sauna Heater, w/ TS30-01 wall controls & rocks Logo
867 people viewed this question
Top Tylo Pool & Spa Experts
john h
David Spradling
David Spradling
Tom Chichester
Are you a Tylo Pool and Spa Expert? Answer questions, earn points and help others
