My macbook air won't let me log into my facebook account. It keeps saying that it is locked. How do I fix this?
This sounds more like a problem with Facebook, try emailing them.
This may have more to do with your Facebook account than with your MacBook itself. Try signing into Facebook from another computer using your user name and password. If your account is OK, change your password. Go back to your macBook and log in with your news password. I have the problem with my Ipad sometimes. Often Facebook will send you a message apologizing for problems logging in. Try logging in from that message.
SOURCE: Macbook keeps restarting
all macbooks have a security that will not let you switch the harddrive from one the the other. Apple will need to reset the computer at an Apple store!!! His drive is DEAD!!!
SOURCE: macbook air internal mic not working
This is a known issue with some of the Macbook Airs - you should bring the machine to an Apple store, or open a case at apple.com
They may be able to repair/replace at no cost, depending on how old the machine is.
Hope this helps, and good luck!
For audio expertise and great AA recordings come over to my website at www.rexark.com
SOURCE: MacBook locked up, won?t close down
The first thing to try is this: It is a keyboard shortcut to shut down a mac laptop. Press the control key (ctrl) at the bottom and press the eject button at the same time (top button all the way to the right which looks like an arrow pointing up with a line under it). This should bring up a window asking if you want to restart, sleep,cancel or shut down. Click Yes to shutdown! If this does not work, here is the second option. Press the power button down on the upper right side,and just hold it down until the computor turns off. I have done this many times with my own computor when it has crashed with no ill effects, I have heard from Apple that it is not good for your computor and can cause problems, so I would only do this if the keyboard short cut does not work Good luck and if you find this helpful please comment!.
SOURCE: My Macbook Air made "beep beep beep" sounds when I
3 x beeps means there is a problem with the memory, either it needs reseating, replacing or a problem with the slots on the logic board.
Kev.
SOURCE: MacBook Air 11" won't power
1. Verify AC power presence with MagSafe LED
indicating on or charge state.
2. Verify battery as being partly charged, with
orange/amber LED on MagSafe power connector.
3. Reset SMC
Resetting the System Management Controller (SMC)
The System Management Controller (SMC) is a chip on the logic board that controls all power
functions. If the computer is experiencing any power issue, such as not starting up, not
displaying video, sleep issues, or fan noise issues, resetting SMC may resolve it. To reset SMC:
1. If computer is on, turn it off by choosing Shut Down from the Apple menu.
2. Connect power adapter to computer and to a working power source.
3. On built-in keyboard, press (left-side) Shift-Control-Option along with power button just
once. Important: Use Shift-Control-Option keys on left side of keyboard.
Note: When the LED on the MagSafe connector is orange/amber, resetting the SMC will
change it to green for a few seconds, indicating that SMC was correctly reset.
4. Wait 5 seconds and press power button to start computer. Note: If bottom case is removed,
you can alternately reset SMC by disconnecting both power adapter and main battery, and
holding down power button for 5 seconds.
Power Adapter Issues
1. Connect AC adapter's MagSafe connector to the
computer. The LED on the connector should be
green or orange/amber.
2. Verify power cord or duckhead is firmly attached
to AC adapter. Check that duckhead is not
damaged.
3. Verify AC power source is supplying AC power.
4. Check for dirty or stuck pins on the MagSafe
connectors, both on the adapter and the
computer.
5. Reset SMC by pressing the (left) Shift-ControlOption(Alt) keys along with the power button
once.
