Question about Epson RX620 All-In-One InkJet Photo Printer
Removing print head
Tried cleaning head with solution did not resolve clogged head problem
5 Related Answers
Anonymous
  • 84 Answers
SOURCE: Removing and cleaning Epson Printheads
I don't know how to remove the print head but if you want to clean it - check for mr.musculo solution from any market near you. Leave the print head in this solution (warmed at about 35 celsius) for several up to 24 hours.
Posted on Jan 15, 2008
yooperbud
Weldon Dube'
  • 8637 Answers
SOURCE: epson 440 won't print
The ink dried up in the print head. A printer should be used at least every two weeks to keep from drying up the ink. You may have to replace the print head or have it serviced.
This is not much help. Bud
Posted on Jan 25, 2009
efs_perpends
efs_perpends
  • 1997 Answers
SOURCE: epson stylus photo 2200 print head removal
Replace the cartridges.
Otherwise, it's unorthodox, but some users have found that this works in your situation. Remove the cartridge, cover the nozzle with a paper towel and use the pointed attachment of a vacuum to clean the dry ink from the cartridge. Be careful not to get ink all over. Then reseat the cartridge and print...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on May 26, 2009
Anonymous
  • 2351 Answers
SOURCE: i have clogged print heads on my CX6600. head
Remove your ink cartridges. Dampen a clean rag with water. Slide the ink cartridges across the rag a few times. The water will break down any harden ink build up and remove it. With the cartridges removed take a few cotton swabs and place a couple drops of water on the cotton swabs. (No dripping). Clean the inside of the ink carriages. Continue this until all ink has been removed. Lastly, place a couple drops of house hold alcohol onto a cotton swab and clean the copper inside the carriage and on each ink cartridge. This removes any oils. Do not touch the copper with your fingers. Re-insert your ink and run the alignment program. Than print a test page. If this fails to fix the problem you may need to replace your ink cartridge. (Always keep your printer covered when not in use). This helps keep dust and excessive air from entering the openings of the printer.
Cheers!
Mike
Posted on Nov 23, 2009
JM Alvis
  • 164 Answers
SOURCE: print head clogged
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
1. Clean your print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Time necessary 45-50 minutes
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
PROCEDURE:
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3.Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY, with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your printer in new condition.
Hope this helps. .
Posted on Feb 08, 2010
Testimonial: "thanks v much for the well detailed procedure. If this works it will have saved me a few hundred pounds"
Canon printer is printing with smudged text, how do I resolve it?
Most Canon printers have a clean print heads function. Search the menus until you find it. This is maintenance you should perform on your printer routinely. Once you do that and it still is smudged, remove the ink cartridges and clean the end of them carefully (you don't want ink to go everywhere). Look where the cartridge(s) connect to the print head. They may be dirty as well and need to be cleaned. Go to the following website and they go into specifics on how to clean your printer:
How to Clean Clogged Printer Heads
Nov 15, 2017 | Canon Office Equipment & Supplies
My Canon won't clean its print heads
Have you tried power cycling the printer?
Feb 17, 2008 | Canon i860 InkJet Photo Printer
I installed a new black ink cartridge and now it won't print black even though it shows its full on in levels
If your black cartridge was empty for any length of time before you replaced it, even if it was still installed in the printer, chances are that the black print head nozzle has dried ink in it. Cleaning may or may not resolve the problem, but cleaning also uses obscene amounts of ink. Epson printers are notorious for clogs since they have some of the smallest print head nozzle sizes (thus their high dpi resolution).
There are some Youtube videos that suggest ways to clean severely clogged Epson print heads. I cannot vouch for them as I have never tried them, but you can view them and decide for yourself.
Feb 04, 2016 | Epson WorkForce WF-3620 Wireless Color...
Remove print head canon mp480
THe print heads are an integral part of each cartridge. When you remove the cartridges you actually remove the print heads. You will need to open the top front panel to access the print carriage which moves left and right over the paper under it. Using cotton swabs you can apply rubbing alcohol to the places the cartridges rest upon and absorb all the dried out ink. Be sure you toss the old cartridges out before you reassemble. If you need to store any ink type printers REMOVE ALL CARTRIDGES and clean off the receivers on the print carriage!
Dec 31, 2012 | Canon Pixma MP480 All-In-One InkJet...
Print job disappearing and not printing
1. Check for a paper jam. Paper jams occur when one or more sheets of paper become stuck in the feeding or printing mechanism. Gently remove any jammed paper and reset the printer.
2. Check ink levels. Those ink cartridges run out fast. If your printer looks like it is printing but nothing comes out on the page, you might be out of ink. Try replacing the cartridge and printing again.
3. Check for a clogged print head. If you know you have ink, the print head might be clogged. Navigate to "Control Panel > Printer > Right Click > Properties > Maintenance > Clean Cartridges" to attempt to clean the print head.
4. Reinstall printer drivers and software. If none of the above helps, try uninstalling and reinstalling the printer and software to correct possible software bugs, errors or conflicts.
Canon-Specific Issues
5. Check printer drivers. Navigate to "Control Panel > Printers > Right Click > Properties > Update Driver" to check for a new driver for your printer. You can also find drivers and software on the Canon Support site (see Resources).
6. Resolve the Waste Ink Error. Press menu on the printer and press scan/copy to enter service more. Press the right arrow to access "NVRAM." Set ABS-M level to 0. Set ABS-P level to 0. Press "Stop" to exit.
7. Resolve Wrong Cartridge Message. Turn off the printer and unplug the power cord. Remove the cartridges and the print head. Clean the print head in lukewarm water. Set it aside to dry. Clean the contacts gently with an eraser and wipe with a tissue. Reinstall the print head and reinsert the cartridges. Run a cartridge alignment.
8. Resolve E0D02 error. Clean the cartridges and the sender strip. The sender strip is behind the rubber drive belt behind the main hatch. It runs horizontally across the machine. Wipe it gently with a lint free cloth.
Aug 19, 2012 | Canon Pixma Mp250 Printer
Hi, (MX850) My blue ink has stopped printing. I
Performing Maintenance:
Note :
Be sure to install the ink tanks in the correct order indicated by the label on the Print Head Holder. The machine will not print if an ink tank is installed in the incorrect position.
Step 1
Printing the Nozzle Check Pattern.
If lines are missing or if white streaks appear
Step 2
Print Head Cleaning.
If the problem is not resolved after performing Print Head Cleaning twice
After cleaning the Print Head, print and examine the nozzle check pattern (Step 1) again.
Step 3
Print Head Deep Cleaning.
If Print Head Deep Cleaning does not resolve the problem, turn off the machine and perform another Print Head Deep Cleaning after 24 hours. If the problem is still not resolved and if you are sure that the ink didn't run out, then the Print Head may be damaged. Contact your Canon service representative.
Hope this helps.
All the best.
Mar 11, 2010 | Canon PIXMA MX850 Multifunction Printer
Wont print black text Is this the 3ebk or the 6 bk cartridge that isn't working, and how might I resolve the problem?
The print head is clogged.Open the cover and first remove the ink cartridges.Then open the holder and remove the print head.Run hot tap
water and put the print head with the nozzles up to stream water.Hold that 5 mins then turn the print head around with the nozzles down.Hold that for every color of 5 mins.Then put the print head in hot water with the nozzles down.Left it water about 15 mins and then you must very nice to dry.When the print head dry put it in printer and start cleaning.If this not help you need to replace the print head.It's part number is QY6-0049.
Nov 04, 2009 | Canon PIXMA MP780 All-In-One InkJet...
MFC 3240C printer head
ph cant be cleaned from outside. It cleans itself by printing with original ink which contains special fluids.
Apr 17, 2008 | Brother MFC-3240C All-In-One InkJet...
Printing blank pages
PLEASE CHANGE THE INK CARTRODGES IT HAS DRY
Sep 22, 2007 | Epson Stylus CX3200 All-In-One InkJet...
Printer won't print color
when you change the ink cartridges you are NOT changing the print head. The print head is in the carrier. If the print head has become clogged or worn then usually it needs to be replaced. Unfortunately it us probably cheaper to buy a new printer.
May 05, 2006 | Epson Stylus CX4600 All-In-One InkJet...
Epson RX620 All-In-One InkJet Photo Printer Logo
76 people viewed this question
Top Epson Office Equipment & Supplies Experts
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
