When i plug it in, it just says batt disconnected on the lcd screen, any ideas?
Hi Anonymous,
I want to help you with your question, but I need more information from you. Are the batteries new? If you did recently replace the batteries in the cartridge, did you check the connections and make sure contact as being made?
Let me know!
Daniel • [email protected] • Power & Systems Innovations • 800.260.2259 • www.psihq.com
SOURCE: Powerware 9120 DC Bus Fault Problem.
there is a 100uf/63v capacitor near the IRF630 fet. You need to replace this in order to fix this error. Along there is also a 2200uf/16v capacitor. It is a good idea to change the both at the same time.
SOURCE: Powerware 9120. 1500i UPS
You can download the manual and other literature at
http://www.powerware.com/EMEA/UPS/9120_info.asp
The contacts for support in India are found at
http://www.powerware.com/India/Service_Support/IN_Office_Contact.asp
They offer a battery monitoring software package, at
http://www.powerware.com/India/Service_Support/IN_Battery_Services.asp
You can email support at http://www.powerware.com/pp/Check.asp?key=code1
Good luck
SOURCE: I have a Powerware 9120 2000 UPS battery failure message
After you replaced the batteries did you perform a manual battery test?
If not do so.
Regards
Alan Hood
ami-man
UK
SOURCE: when the machine is power on it show disconnect
There may be a broken batt lead or a failed cell or bloc inside.
try checking with software or
take out batts and test with meter.
if you dont understand how then get a tech to help. batts are dangerous.
SOURCE: replacement fans for powerware 9120
9120 fans are rare and uncommon, for alternate solution just replaced the bearing of the fan.
The charger board has fail. No point replacing it. Better to buy a new. This unit has already been obselete
