Question about Hobart SR24-H Built-in Dishwasher
Why doesn't dishwasher heat properly?
Heating element is good, contactor is new, however, as I watch through a cycle, the contactors never engage to fire up the element. Is the temp sensor bad, or maybe the relay that controls the contactor? How can I test? Thanks.
4 Related Answers
paultech8226
  • 109 Answers
SOURCE: lx30h hobart dw. booster will not turn on. element
The booster heat control circuit is controlled by the relay board. Visually check for loose or burnt relay contacts...
You will see the booster LED light when it calls for heat. Some newer machines have a second high limit on the right hand side of the booster tank.
It may be your control board is configured for low temp with no booster. When you power up, the display should say LX30H. If not
Pull open the upper drawer, place a magnet over the door interlock switch.
CAUTION, 220 volt power is present. be carefull what you touch.
on control board, short J5-1 and J5-2, then power up. You are in factory setup. press select on the control board to see each option on the front panel., press up arrow on control board to step up through options for each step. when done, press the off button on front panel. remove short and start up normally. With the magnet in place, AND THE DOOR CLOSED, run the machine and observe the relay board status lights.
If you want to adjust the temp set points, with the machine off, press and hold the hidden key behind the front panel logo, and press select on the control board.. Or on power up, hold the wask key..Same to adjust options as above. Press off to exit.
Posted on Aug 08, 2009
Anonymous
  • 70 Answers
SOURCE: No heat -element is good. Heating contactor not
1)check the heating element continuity&body resistance ok.
2)check the thermostat series with the coil connection get tripped.(relay from board damage)
Posted on Jan 07, 2010
Anonymous
  • 110 Answers
SOURCE: no heat on rinse cycle HOBART AM14C Dishwasher
ITS MOST LIKELY A HATCO BSTR . IF THE TANK CAN BE SEEN ITS NOT HATCO.FIRST JUMP OUT T'STAT ON BSTR SO ITS ALWAYS CALLING FOR HEAT CK. ALL ELEMENTS FOR AMPERAGE. BE QUICK SO BSTR. DOES NOT OVERHEAT ON YOU.IS CONTACTOR STILL CHATTERING, IF NOT REPLACE OPER. T'STAT FOR BSTR
Posted on Jan 11, 2010
dprcn33
Dennis Perez
SOURCE: rinse temperature too low
your right dont guess the board is bad!
Posted on Dec 13, 2012
Electrical issue When does the K2 heating element contactor pull in?
Likely 2 stage heat. If you raise the temp, say, 10 degrees, it should call for 2 stages of heat.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jul 24, 2017 | Heating & Cooling
Vulcan ducted heating
Do a continuity test on the heating elements, and if they're good then do the same on the sequencers or contactors, whichever you have. The sequencers (or if you have contactors turn on the heating elements). All the fan does is blow air. It blows against the heating element to put out hot air. Either your sequencers/contactor or your heating element is defective.Wait,each sequencers is connected to a fuse.Check the sequencer fuse too. Find the sequencer/contactor wherever the wire feeding the heating element is coming from.
Aug 20, 2013 | Heating & Cooling
I have the Mr Steam MS Super 1 T steam unit with the Tempo Plus accessories and auto flush. The unit has worked great for about 2 years but for some reason yesterday the unit light comes on at the...
You would need a multi-meter or voltmeter to trace the power path. Turn on the generator and wait until you hear the water feed solenoid stop. This means the water has reached the satisfied level and the pc board should have sent 24v to engage the contactor. On the actual pc board there is a section label "cont" which is what sends the 24v to the contactor the engage the heating element. Verify that you have 24v on the spade terminals going out to the contactor, if not then you may have a pc board issue. Second possibility is the contactor, if it is recieving 24v and it is not engaging then it's simply a bad contactor. Check the load side of the contactors with the blue wires. Lastly if these two steps check ok, then perform an ohm reading with a multimeter on the actual heating element(with the power off, put your two test leads on the two flathead screws that hold down the blue leads the go to the heating element). If you get an open reading then this may indicate a failed heating element. Pulling the heating element out on the left side panel will confirm any element failure.
Nov 08, 2012 | Mr Steam Ms Super 1e Steam Shower...
Our Dualit toaster doesn't work. The red light doesn't work. I have changed the fuse in the socket with a working one. The timer turns normally. Yet none of the heating units heats...
You need to replace the timer-contactor. This part is acting both as timer and electrical contactor. It consist from electrical contact moved with springs on and off. Due to electrical load and extreme heat these contact have been tear out thus they can not contact properly and in your case they don't contact at all.
So from the web page of dualit or ebay you can order A new timer contactor and replace it.
Jun 12, 2011 | Dualit Vario 3 Slices Toaster
Will not heat up
it will if the boiler is not up to temp may have dead element in rinse boiler or contactor
Apr 29, 2010 | Indesit 18 in. D41 Slim-Line Free-standing...
I have a Zanussi ZSF 6160 dishwasher which is not heating the water. I've checked the PCB and visually it appears ok. How do I change the heating element?
measure the heating element resistance it should be around 25 ohm.
otherwise it is the problem.
You can replace the relay, sometimes it stop working with no external damage signs
Jan 08, 2010 | Zanussi 24 in. ZSF6160 Free-standing...
No heat -element is good. Heating contactor not pulling in,no 24 volts to contacter coil
Jan 06, 2010 | Hobart AM14C-155 Dishwasher
Where can i find a trouble shooting guide for this unit
The wash tank heating element is control by 1. the dual Float switch 2. The temperature control 3. the high limit thermostat 4. Contactor 5. tank heat fuse 6 element itself. Hope this help. God Bless.
Feb 12, 2009 | Champion CG Dishwasher
Heating element remains on
Hello JLH2433,
Depending on thebrand and model.. you may have one of several problems with your stove. Your heating element power may be get its power via a relay or contactor which may be stuck on all the time. To de-energize it, you remove main power and it actuates to the Normally Open position but when you select that element to be turned on and the contactor/relay is switched from Normally Open to energized and Normally Closed, it provises power to that element. You may have a bad relay/contactor ofr the controller is defective. Removing power will deenergize the relay/contactor but that contactor is a slave to the controller, 50/50 which component is the root cause of your problem..
Oct 12, 2008 | Ovens
Heats up water slowly, only by repeated operation
The wash tank element should be operated through a 3 or pole contactor which gets its power only when the rinse tank has come up to temp and switched the thermostat over(rinse tank heating takes priority). Is the rinse tank element fully intact ie-is it pulling its full amperage or is part of the element blown causing it to take longer to heat? Is the rinse contactor dropping in when the thermostat for the rinse tank is turned fully down? It sounds like a thermostat or contactor problem- good luck and let me know how you get on. Kitcheneer
Mar 24, 2007 | Champion 26 in. D-HBC Free-Standing...
Hobart SR24-H Built-in Dishwasher Logo
81 people viewed this question
Top Hobart Dishwashers Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
