Question about Olympia InfoGlobe Caller ID
How do I get InfoGlobe phone to work?
The phone will pickup a call or take a charge. Too kit to Radio Shack for bat replacement, If that was the Problem?, but they didn't have that type of bat. Is there a NEW phone replacement available? If so, how much? Thanks, Ken
Where can i buy a replacement battery durabrand li-ion model bat-09 7.4 v 2800mah
you can find in radio shack or computer stores or electronic suppliers parts.
God bless you
Jul 12, 2012 | Durabrand PDV-709
I have a CTP8600 Cordless phone made by Coby in 2003. The battery pack for the handset is apparently no longer charging. Coby has stopped making (or supporting) this product. I would like to replace the...
Try taking the battery pack to your local radio shack store. They can usually match the original battery pack with a new, compatible one even if they no longer make the EXACT one that came with the phone. This recently happened to me with a panasonic phone bought around 2002. phone stopped charging, no longer make the phone, etc. I went down to radio shack and they fixed me up with a new battery (not exact brand/part number as original) and it worked. Hope this helps you.
May 20, 2011 | Coby CT-P8600 Cordless Phone (CTP8600)
I am installing a new/different radio in my
stop in walmart or radio shack and pickup a install kit and that way all you have to do is plug it into the plug you have and you then know where the wires go wish you the best of luck Michigan Man
Nov 27, 2009 | Hyundai Motor 2004 Sonata
Dvd drive
Make sure it is not your DVD by trying several others or verifying that your DVD works in a different player. If your DVD is OK your player may just be dirty. You can try cleaning the laser detector. Pickup a DVD lens cleaner kit at Radio Shack or Best Buy. If that doesn't do the trick, buy a replacement, they are very cheap now.
Aug 25, 2009 | Philips (JR4DVDRWK/00) DVD+RW Burner
Wont charge
Usually when a rechargable  battery won't take a charge it need to be replaced.  I have had good luck purchasing replacement phone batteries on ebay but you can also try a local phone store or Radio Shack.  Its possible your charger is bad but it is usually a bad battery as they have a finite life where the chargers seem to work forever unless damaged by being dropped
Apr 25, 2009 | Motorola Mobility W375 Cellular Phone
Phone is not working
It is not worth to fix it.  I just got a new one.  Thanks!
Aug 07, 2008 | Olympia InfoGlobe Cordless Phone ol3020
Wired base unit
Try a simple thing, replace the phone cord that goes from the wall to the phone with a new one. That'll make sure you still have a good phone connection. Cords cheap.
You have a power transformer that plugs into the wall.  See if you can find a replacement at a surplus store or Radio Shack (a different store)  Take the old one with you so you can match the voltage/ampere and connector.  If its new it will work fine.  If its surplus, it's hit or miss.
If that does not work  or you don't want to bother buy as new phone.  With the constant upgrades you might find one with better features you'll like more.  Who knows.
Good luck
Oct 25, 2007 | Dual Maxus 5.8GHz Handset Cordless Phone
Olympia InfoGlobe Caller ID Logo
136 people viewed this question
Top Olympia Lands Phones Experts
Bruce Robin
ray gallant
Tom Chichester
Are you an Olympia Lands Phone Expert? Answer questions, earn points and help others
