Question about Zebra ZM400 Thermal Label Printer - ZM400-3001-3000T
I cant perform anything on my printer because when i turn it on it comes with a ribbon and paper out error.what should i do
Paulo Rangel
    Champion:
  • Zebra Expert
  • 285 Answers
Please check if you fit the paper and ribbon at correct place (under the crome plate and between the printheard and white roller.
Posted on Aug 23, 2014
How to fix an error?
First of all check that the ribbon core is correctly placed with the notches fitting on the Green wheels. If th ribbon coe is not secured the wheel will not turn and no ribbon will be detected. If your core is too short and with no notches, you'll have to glue a pice from another core an create a notch.
May 30, 2014 | Toshiba TEC B-452 Thermal Label Printer
My 510s is having issues with printing. The print ribbon is sticking to the paper, thus tearing the ribbon and causing a paper jam.
Remove any slack in the ribbon by turning the ribbon-tightening knob, or reinstall the ribbon cartridge...
First Turn the printer off, open the printer cover and remove the jammed paper if paper is jammed..
***If you need any technical help on printer then you can reach at here
Jan 02, 2013 | Unknown Hiti P510s 6 Dye Sub Roll-type...
Hi. I have recently installed the Canon MX870. Everyting works OK. However, it comes up with a paper jam error quite often, i check all the places a paper jam could be, then press the OK button and the...
If the printer is still under warranty I would try to get the Canon tech support to help fix it or replace it. If not, look very carefully for any tiny bits of paper that could trigger the sensors. You may also use an air can to blow out hidden particles.
Hope this helps...
Steve
i
Jan 14, 2011 | Canon PIXMA MX870 Wireless Office...
Everytime I turn my Zebra TLP 2844-Z printer on,
The red light means out of paper or ink ribbon. Some people chose not to use the ink ribbon and get thermal direct paper which requires no ink ribbon but the printer has to be told by the driver not to expect ribbon or the red light will come on. Also not having the correct paper height set in the driver will make the red light come on as well so check the advanced tab in the properties of the driver then click printing defaults. In the ZDesigner driver height and width are entered there. In the zebra universal, click paper output and enter the size.
Oct 01, 2009 | Zebra TLP 2844-Z Thermal Label Printer
I am getting error when I send print job to Kodak 1400 thermal printer. The media light flashes but can't find anything wrong with paper or ribbon. Any suggestions ?? Thanks. Debby
Hi Debby,
If you remove the paper tray and the cradle holding the ribbon you will se a BLACK holder on the RIGHT hand side of the machine were the Ribbon Cradle sits.
At the bottom of this BLACK holder you will see a small hole. If you get get a cotton bud and put some glass cleaner on it and wipe the 2 sensors in this hole. Replace the Cradle and Paper tray and try it now.
If this does not work have you tried checking that you have set the right paper size and type in Printer Properties.
Thanks
Gary
Mar 15, 2009 | Kodak PRO 1400 Thermal Photo Printer
Error conditon ribbon out
if you are not using a ribbon you should configure your printer properties in direct thermal the same with your printer configuration in LCD Panel, if your printer properties is different with the LCD Panel error condition ribbon out will come out to your LCD Panel
Jul 27, 2008 | Zebra Z6M Plus Thermal Label Printer
Printer error, only prints one color
Did any of the ribbon come away, or tear when it broke, i have heard of small pieces lodging in the carriage or feeder. Check this very thoroughly as blockages can be very tiny. Check you correctly inserted the ribbon too, and it is the correct type of ribbon for your unit. (sounds silly but sometimes it ccan be that simple) try reinstalling printer, is the ribbon cartridge faulty? check it.
Aug 10, 2007 | Olympus P 400 Thermal Printer
PRINTER ON/OFF
op the ink cartridge protective door located above the ink cartridges. remove both cartridges. look at the white ribbon cable that connects to each cartridge. You will see gold dotted connections. look closely for a small hole in the cable . This hole is caused by the spring that holds the cartrdges in. Sometimes people force the cartridge in puncturing this ribbon cable. It is a poor design by HP . The error code will usually say ink cartridge door not closed. Unfortunately the assembly is fairly difficult to replace and can cost as much as to printer. If you bought new cartridges, buy asimilar unit which uses the same cartridges. Then at least its not a total loss. Scrivitron
Jun 19, 2007 | HP OfficeJet 9120 All-In-One InkJet...
Datamax allegro2 error
if you have it set to use thermal ribbon and dont use 1 then you can get this error..
put a ribbon in or there is a switch located inside the case near the feed switch turn it off
Jan 15, 2007 | Datamax Allegro2 Thermal Label Printer
Zebra ZM400 Thermal Label Printer - ZM400-3001-3000T Logo
376 people viewed this question
Top Zebra Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Marvin
Marvin
Muntejaya Ginting
Muntejaya Ginting
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
