SOURCE: my garmin nuvii 200 is stuck on a foreign language
Ah ha, someone decided to play a little joke with your Garmin. (I've done the same with someone else's cell phone; set it to Portugese and they'll search for days to correct it!) Fortunately, all of the Garmins I've played with are typically icon driven menus. I'll assume you touched the wrench icon in the lower right corner to get into the setup display. From there, you should see icons for 'Map', 'System', 'Time', etc. If you don't see the 'Language' icon, use the down arrow to go to the next screen. If that doesn't help, I would do a factory reset and that should take you back to the factory settings.
SOURCE: garmin stuck on foreign language
Turn the unit off. push the lower right corner until the unit comes on. a page will appear with the arabic and it will show 2 radio buttons push the right hand one and it should reset.
SOURCE: garmin nuvi 760
Go to tools-settings-language-voice and make sure it is set to "American English-Jack (TTS) or to American English-Jill (TTS)
SOURCE: Garmin 760 - No Voice Directions
Check The system settings, I had to download the newest version of the audio software for the voice to work. The software vanished once and I had to re-download it using the web updater.
Hopefully it will stick around this time.
When I load the new software the voice works.
SOURCE: I cannot get my Garmin
there is a master reset switch on the back of the unit take a small pin or something and reset the unit to the day you bought it
