Question about Kenmore HE2 Plus Front Load Washer
I have an F11 code on my kenmore front load washing machine
Eran Sitnik
    New Friend:
    Problem Solver:
  • 12 Answers
After years of suffering from random F11 that became a permanent F11, I did the repair as in the video and all is good for 2 years. No more F11. About one load a day (we have kids!)
Posted on Jul 14, 2016
Thomas Beaver
  • Kenmore Master
  • 2,119 Answers
Posted on Aug 22, 2014
1 Related Answer
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elite HE3 front loading washing machine(F11 code)
"F11" is a Serial Communications error between the Central Control Unit (CCU) and Motor Control Unit (MCU). The CCU is the main computer for the washer and is located directly behind the wash tub. The MCU is the Drive Motor Control board and is located in the rear of the washer adjacent to the Drive Motor on the left-hand side (facing from the rear with the back panel removed). The wiring harness can also cause the error, but it is not as common a problem.
Whirlpool is the manufacturer of both model washers and recommends the following troubleshooting advice. Remove the top panel of the washer by removing the three screws holding it in place in the rear. Once the screws are removed, the panel slides back, then off. Remove the rear panel of the washer for access to the drive motor and MCU. Now check the following:
- Check the wire harness connections between the CCU, the MCU and Drive Motor. Make sure all connections are attached and making good contact. Check for any broken wires or connector pins.
- Check the Drive Motor to see if it free spins and that the belt is still attached and not slipping. If the motor is seized, replace it. If the belt is broken or worn, replace it as well.
- Check the MCU. Connector 1 is the Serial Communications Link between the MCU and CCU. Connector 2 is the connector to the drive motor. Resistance checks across pins 1, 2, & 3 are the motor windings. Connector 3 is the power supply - 120VAC should be read across pins 1 and 2 with the door in the locked position. NOTE: The connectors are read 1, 2, and 3 from the bottom to the top with the MCU installed.
- Check the CCU. Verify connectors 7 and 11 are properly installed. Facing from the front of the washer, connector 7 is the 4th connector from the RIGHT along the front. This is MCU Power. Connector 11 is the Serial Communications link from the CCU to the MCU and is located along the left hand side of the CCU (the connectors are numbered 11 through 14 back to front).
- Check the Drive Motor. Remove the connector and perform resistance checks on the motor connector pins. Readings across pins 1 to 2, 2 to 3 and 1 to 3 should read 6 ohms.
In most cases this is an indication of a failed CCU. This is an easy repair that the average do-it-yourselfer can accomplish on their own. If the washer is still under a warranty, parts and labor would be covered. With no warranty, a replacement parts will vary in price depending on where you get them. There are several good websites available that you can order parts on line and have shipped directly to you.
NOTE: Remove all the connectors from the CCU ONE AT A TIME and reconnect to see if the error code goes away BEFORE you decide to purchase a new one. It is not common, but sometimes a flaky connection can generate error codes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
Posted on Sep 11, 2010
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
if its a Kenmore model then this message says that the button control board has lost sight of the main control board , but its been my experience that this maybe able to be reset and it may never come back or it will not reset and the control board will need replaced (50/50)
cycling power may reset this
Jan 30, 2016 | Dryers
Whash machine
The symptoms are pretty specific for the F11 code on the Whirlpool Duet front loaders and clones (Kenmore Elite and KitchenAid):
If the washer starts to fill but the drum NEVER moves, your MCU is bad
If the washer runs through most of a cycle and then gives the F11 before (or during) a rinse or spin cycle, then you have the CCU relay problem.
If you are interested in having me repair your CCU for you, I offer that service on eBay (website coming soon). My username there is "jhagner"
Thanks
Feb 04, 2014 | Kenmore HE4t 3.8 Cu. Ft. King Size...
What does the f11 code on a kenmore elite he3 washer mean
A bad CCU (main control circuit board) will cause this F11 problem 90% of the time
Aug 26, 2010 | Kenmore Elite 45986 Front Load Washer
Cylce stops after 1st drain before spin out
I have kenmore washer front load H2 after 1st circle of wash it stop and start beeping with code F11. My email address is [email protected] live.com
Jan 21, 2010 | Kenmore HE2 Plus Front Load Washer
Maytag Epic giving F11 error code!
ths.gardenweb.com/forums/load/.../msg1012004912002.html
Jun 22, 2009 | Maytag EPIC MFW9700S Front Load Washer
FAULT CODE F11
F-11 like a Kenmore means communication error between the motor control and the main control. Check connections, unplug and replug computer connections and see if problem persists. I've seen cases where either board or even both can be bad.
Feb 08, 2009 | Whirlpool AWM8143 Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
683 people viewed this question
Michael Thomas
Michael Thomas
Paul Carew
Nicola Conroy
