Question about Lands Phones
Programming instructions how do I change names on my norstar meridian mt7324 phone?
John Canter
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 19 Answers
You will need to log in to user programming by dialing Feature **266344. Then enter the default password 266344. Your password may be different depending on your phone company. Use the navigation keys (line keys lit up) to navigate. Scroll using the bottom right key until you see "General Admin". Press the top-right key to select. Scroll right until you see "Names" and select it. Select "Set Names". Enter the set number, then use the dial pad to type the desired name. When done, press Rls, or press the top left key twice to go back and select a different extension.
Posted on Jun 01, 2020
5 Related Answers
Anonymous
SOURCE: nORSTAR m7310
To Log Into System Programming:
Press FEATURE * * 2 6 6 3 4 4
Enter Password: 2 6 6 3 4 4 Display will read: " A. Configuration"
Using the navigation keys, as displayed below, follow the next simple steps:
Press: NEXT Display will read: "B. General Admin"
Press: SHOW Display will read: "1. Sys speed dial"
Press: NEXT Display will read: "2. Names"
Press the SHOW Display will read: "Set names"
Press: SHOW Display will read: "Show set:__"
Enter the extension number of which you wish to change the name Display will read: "<##:name>"
Press the CHANGE softkey
Using the dial pad spell out the name Ex: If you need the letter K press the 5 key twice and then press # to confirm the letter. Continue until the entire first name is spelled. (note: you are limited to 7 characters)
Press: NEXT (if you fail to do this step, the name will not be saved!!!)
Press the RLS key
Hope this helps!
Posted on Jul 27, 2008
Anonymous
SOURCE: Our office has 13 phones
You will have to go into system programming, under sets, line appearances. You will need to set the lines on the phones to appear and ring, not just appear.
Posted on Jan 03, 2009
Anonymous
SOURCE: Nortel Norstar T7316E phone programming
feature 983 it will ask for log number use code 120000 for 2 number extensions, for 3 letter extensions it is 1020000, and 4 is 10020000 once in this screen hit MBOX then CHNG and put in mail box number then hit next until you get to the name and press CHNG and you can change it using the the number corresponding to the letter I hope this helps
Posted on Jan 08, 2009
cnavarro
Carl Navarro
  • 2460 Answers
SOURCE: Nortel Meridian Norstar-Plus Compact ICS with #7310 phones.
I'm pretty sure CID is automatic on a CICS....IF you have a CID trunk card. You might want to post the part number on the face of the trunk and we'll see if it's the proper one.
Carl
consultel1
george peters
  • 860 Answers
SOURCE: Find free complete user manual for 7310 Meridian Norstar system
The 7310 is a phone model number. The system is going to be a CICS, MICS, or a BCM. If you look on the top corner of the box it should be there. Once you find out the model go to http://pdf.textfiles.com/manuals/TELECOM-F-R/
that should help with documentation.
Posted on Feb 13, 2009
Why doesn't one phone in my norstar meridian m7310 phones is not displaying caller id
Either COPY the config settings from a set where it works to those that don't, or on the sets that do not:
F**CONFIG, Terminals&Sets, (enter ext #), ... Telco Features, 1st Display Name: change between Name, Number, or Line.
And remember that some callers (esp Cellphones) do not provide Name info, so if the incoming calls at that extension are mostly from the same #s, it might be normal.
Aug 11, 2014 | NorStar Meridian M7310 Phone
Norstar Meridian how to turn on the ringer
From the following web site:
http://www.telephonemagic.com/phone-support/norstar-feature-programming-code.htm
To Change the Ring Volume:
1. Press the Feature button, then * 80
2. Press the volume key up or down
3. Press the release key1 to exit and save the volume level
Jun 15, 2012 | NorStar Meridian M7310 Phone
I need someone who can help me do some programing with our small business Norstar system--changing the main greeting, after hours greeting, mailbox issues, etc.
I need to chane the main greeeting on the Norstar T7316E and the message that lets you go to different people mail boxes, it is already programmed , but I would like to change it, Thanks
D
[email protected]
Aug 28, 2010 | NorStar Meridian M7310 Phone
How do I find out what my extension number is on my meridian phone
Press feature *0(button inquiry) then your intercom button(last or second to last on the right row of 5 buttons). It will display your intercom number and name if programmed.
Aug 14, 2010 | NorStar Meridian M7310 Phone
Want to purchase a manual for Norstar 7310 telephone system. We have lost ours.
Meridian Norstar Programming Manuals Available. Call 905-204-6970 for details.
Link: http://www.alphatelecom.ca/meridian_norstar_manuals.htm
Jun 25, 2010 | NorStar Meridian M7310 Phone
Previous users name comes up on screen, how to get rid of his/hers and insert mine? Do you have a user manual for the m2616 meeridian?
Those 2 items are "mutually exclusive". Take your 2616 phone and plug it in somewhere else and you'll see why. Unless you have auto set relocation, you will, indeed, change the display name.
Programming is stored in the PBX, possibly an "Option 11c". http://www142.nortelnetworks.com/mdfs_app/techdoc/enterprise/cs1000/M125_40/pdf/NQZHZWQH.pdf
Start looking in the 70's for instructions.
Carl
Mar 10, 2010 | NorStar Meridian M2616 Phone
What is a Norstar Overlay Template?
right top Show
right bottom Next
left top Heading
left bottom Back
Mar 23, 2009 | NorStar Meridian M7310 Phone
Merian M7324 display name
you would need to get into the admin programming to change the name, have your system admin person make the change for you.
Jan 02, 2009 | NorStar Meridian M7310 Phone
Need to change the names on display within the office alls
You have to go into programming under sets, and change the name. If you are unsure how do get into the system admin, then I would call a professional in, as you can do more harm....
Dec 17, 2008 | NorStar Meridian M7310 Phone
Lands Phones Logo
54 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
