Question about Clymer Mercury/Mariner 2.5-60 HP Two-Stroke Outboards Includes Jet Drive Models 1994-1997
Engine diagram parts
How can I unblock the cooling system of a Mercury 60 engine water not coming out when running engine ?
phillipelecu
    Champion:
  • 254 Answers
Have you replaced the impeller in the lower unit recently? If so was it in pieces? I would start there.
Posted on Jan 28, 2015
What might cause the warning system on mercury 50hp outboard to beep 3 times every 4 minute s
That is the engine default code. It has to do with the regulator not getting enough water to cool it down. Those are water cooled regulators not air cooled like cars. The impellers for the cooling system should be replaced about every 3-4 years. It may still cool the motor but not enough to cool the regulator which supplies the computer to set the trouble codes.
Jul 21, 2018 | Mercury Boating
How to bleed air from cooling system on 2003 mercury sable 3.0 DOHC
To begin with, if the cooling system is tight ( no leaks ), the cooling system will "self-bleed" by starting the motor, and turning on the heat so that the coolant will circulate through the engine and through the heater.
The water pump will keep the coolant moving , and the trapped air will rise to the coolant tank.
The engine will need to be running for at least 10 minutes to get
all the air to come to the recovery tank.
During this process, the recovery tank must also be kept full.
God bless your efforts.
Jun 26, 2018 | Mercury Cars & Trucks
Mariner 15m 1996 shifter stuck in foward
you did this without any water cooling it . SHAME SHAME on you . you might have welded the clutch dog to forward gear . these were not built to run out of water ever
Jul 22, 2016 | Clymer Mercury/mariner 2.5-60 Hp...
Why won't my mercury marine engine not restart after running for 30 or 40 min.
is it cooling ok ? run on hose and check engine block and exhaust plate cool ! water inlets clear and impellor good condition ? compressions all over 100psi ? carbs clean ?
Jul 23, 2014 | Clymer Mercury/Mariner 75-225 HP 4-Stroke...
How do I put water or coolant in my 1994 Mercury Topaz?
ON TOP OF THE RADIATOR THERE IS A SCREW CAP , 3/4 TURN ANTI CLOCKWISE DON'T TRY TO OPEN IT WHEN THE ENGINE IS HOT .
Jun 30, 2014 | 1994 Mercury Topaz
1993 Mercury Tracer running hot
"rule out" questions - is coolant level OK? Any leaks, especially around the water pump? Has the system ever been flushed. out? If this is the original radiator, it could be clogged. Is the thermostat installed correctly with spring end toward the engine?
Mar 22, 2014 | 1993 Mercury Tracer
Im not sure what it is i am looking into buy this 1997 grand marquis and the guy said that there is a water leak the goes into the engine to cool it what can this be
either the water pump is cracked somehow or it can be the cooling system. liquid cooled engines have a cast- iron jacket surrounding the cylinders, that coolant or water flows through. if this jacket develops a crack or hole the coolant or liquid will flow through it, as a running engine and high temperatures create a lot of pressure.
Feb 10, 2011 | 1997 Mercury Grand Marquis
My 94 Merc Villager has been overheating and I have no heat coming through heater. I had the system flushed, thermostat changed. Water pump checked okay. Mechanic says engine is the problem and needs...
You have air trapped in the engine and heater system. very common on today's engines. You can try burping it yourself, or go to a shop that can flus your cooling system for $60 and refill using a vacuum system that purges all air by sucking it out. Then you have to keep reservoir full to keep it from sucking air back in. Temp gauge should read on the "A" in normal on the gage.
go here and read files on how to do yourself. it's hard to do.
http://groups.yahoo.com/group/villagerquest/
Jan 11, 2010 | 1998 Mercury Villager
Cooling fans 1997 mercury mystic
How hot does the engine get in degrees F ? Some radiator fans won't turn on till about 220 degrees F ? Knowing the actual temp would help.
Is your coolant boiling over or anything? Sometimes when cooling system is opened, it might get air in the system?
Feb 10, 2018 | 1997 Mercury Mystique
Clymer Mercury/Mariner 2.5-60 HP Two-Stroke Outboards Includes Jet Drive Models 1994-1997 Logo
260 people viewed this question
Top Clymer Boating Experts
Colin Stickland
Colin Stickland
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Clymer Boating Expert? Answer questions, earn points and help others
