Car Audio & Video Logo
Question about Aiwa Car Audio & Video
How to wire a AIWA RF-M60
How do I wire A AIWA FM modulator RF-M60 into my 2011 F250?
1 Related Answer
Anonymous
SOURCE: i need RF Module FM
here's a link
http://www.tradeage.com/sale/ftrf01-fm-rf-module-ce179540
Posted on Aug 27, 2011
2answers
I have a 2011 Jeep Compass the am/fm will not work but cd and satellite work any ideas?
Check used on the rear of the radio or plug in the antenna cause I might have come unplugged
1helpful
2answers
RECEIVED RF ON AIRCRAFT BAND BUT NO SOUND
Check for mode or modulation type setting. Aircraft use AM modulation, most other radio bands will use FM.
1996 sharp tv model # 25H-M60 co-ax pulled out from the circurt board. I removed the back of the tv,and can see the female end is snap off the case that houses the board. Can i solder that back to the...
That is what the service provider would do if you took the television in to be repaired. The service provider would attempt to solder the rf connector back to the television or solder a new rf connector to the television.
How to: Aiwa CRDL101 am/fm stereo (2x4 handheld unit) no manual
Sony bought Aiwa in 2002. You can download the manual from Sony's web site at
http://www.docs.sony.com/release/CRLD101.pdf
5helpful
2answers
How to adjust frequency on transmit??? Galaxy
hELLO THERE
hERE IS SOME MODIFICATIONS FOR THIS RADIO
Galaxy Mods DX 2527 - VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR11...Driver Bias, VR12...SSB ALC, VR13...Hi Power, VR14...AMC, VR15...AM Low Power, VR16...SSB Low Power, VC 1....10.240, VC 2....10.240. DX 2517- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5....FM Deviation, VR 6....SSB Carrier Balance, VR 7....TX Offset, VR 8....CW Beep Level, VR 9....RF Meter, VR10...Final Bias, VR11...Final Bias, VR12...Driver Bias, VR13...SSB ALC, VR14...AM/FM High Power, VR15...AM Modulation Meter, VR16...AM Modulation, VR17...SSB Power, VR18...AM/FM Low Power, VR601..13.8 Volt Power Supply. DX 22B- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR11...Driver Bias, VR12...SSB ALC, VR13...High Power, VR14...AMC, VR15...AM Low Power, VR16...SSB Low Power, VR21...TX Offset, VC 1....10.240, VC 2....10.240. DX 11B- VR 1....AM/FM S-Meter, VR 2....SSB/CW S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR10...Final Bias, VR11...Driver Bias, VR12...SSB ALC, VR13...AM/FM High Power, VR14...AM Modulation, VR16...CW Tone Level, VR20...Final Bias, VR21...TX Offset, VR601..13.8 Volt Power Supply, VR803..AM/FM Low Power. DX 77HML, DX 88HL, and DX 99V- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR10...Final Bias, VR11...Driver Bias, VR12...SSB ALC, VR13...AM/FM High Power, VR14...AM Modulation, VR16...AM/FM Low Power, VR20...Final Bias, VR21...TX Offset.
Unmarked VR in R189..AM/FM Medium Power for DX 77HML only. DX 33HML, DX 44V, DX 55V, DX 66V, and DX 73V- VR 1....AM/FM S-Meter, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 8....RF Meter, VR12...Low Power AM Modulation, VR13...AM/FM High Power, VR14...High Power AM Modulation, VR16...AM/FM Low Power.
Unmarked VR in R188..AM/FM Medium Power (DX 33HML only)
Unmarked VR in C139..Med Power AM modulation (DX 33HML only) DX 949,DX 959- VR 1....AM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM Squelch Range, VR 6.....SSB Carrier Balance, VR 7....TX Offset, VR 9....RF Meter, VR10...Final Bias, VR12...Driver Bias, VR13...SSB ALC, VR14...AM High Power, VR15...AM Modulation Meter, VR16...AM Modulation, VR17...SSB Power, VR18...AM Low Power, VC1....10.240. DX 2517 and DX 2527-
Symptom:Buzzing or motorboating sound in either the transmit or receive.
Problem: TR602 is oscillating
Cure: Replace C602 with a .01uF cap {Cap is located in the power supply board}.
RG 66,99,DX2517 Replace Q54 2SB754 60watt 7A with a higher power 2SB817 100 Watt 12A. Derating of this component will cool operation, provide better voltage stability,decrease wobble, allow voltage increase to 14.5 volts comfortably. (replace 10 volt caps in this section of the radio to a minimum of 16 volts before increasing supply voltage to this level)and provide faster swing rise time, Replace Q37 2SA473 to a 2SA1012-0 or ECG153 this will improve the clarity and volume of the modulation and it will also run a lot cooler.
Can I plug an mp3 player into the unit ???
Hi, A wild guess, the 2 X RCA are lineout intended for external amplifier hence no AUX selection in your front panel buttons, but of course I might be off. I have similar problem with a Pioneer model and an MSI MP3 player. My solution was to install a stereo FM RF Modulator similar to Delphi SA10003 or an AudioVox Rf Modulator FMM100a. The MP3's output was fed to the modulator which turns it into an FM broadcast. The car stereo picks it up as an FM signal. Hope this gives you some idea. Good luck and kind regards.
1helpful
Help
Yellow - +12V Constant Power Red - +12V Switched (accessory) Power Blue - Power Antenna Blue/White - Amp Turn-on White - Left Front Positive Speaker Wire (LF+) White/Black - (LF-) Gray - Right Front Positive Speaker Wire (RF+) Gray/Black - (RF-) Green - Right Rear Positive Speaker Wire (RR+) Green/Black - (RR-) Purple - Left Rear Positive Speaker Wire (LR+) Purple/Black - (LR-)
Top Aiwa Car Audio & Video Experts
AAA TV Service
AAA TV Service
ADMIN Andrew
ADMIN Andrew
Marvin
Marvin
Are you an Aiwa Car Audio and Video Expert? Answer questions, earn points and help others
