Question about Samsung Galaxy S GTI9000 Smartphone
Imei blacklisted phone is reactivation locked and dont no what to do. is an s5 sm-g900i android version 4.4.2 can anyone help?
4 Suggested Answers
Jesse Welch
  • 26 Answers
SOURCE: caller getting rejected and not in blacklist
Try removing their contact and re-adding it, sometimes that works for me when things get a little hinky. It is probably a ghost setting where it is either so hidden in menus you will never find it or the phone is not receiving the signal to not block for whatever reason. But if that doesn't work I would have them check their phone for potential block lists etc. Also you could call your carrier and see if they know of any issues that could be causing it, and have your friend do the same.
Posted on Mar 29, 2012
easybill99
Rani wadia
  • 996 Answers
SOURCE: i want to know all the secret code of samsung like how to check imei, softare version, any information of my device through code?
*#1111# S/W Version
*#1234# Firmware Version
*#2222# H/W Version
*#8999*8376263# All Versions Together
*#8999*8378# Test Menu
*#4777*8665# GPSR Tool
*#8999*523# LCD Brightness
*#8999*377# Error Menu
*#8999*327# EEP Menu
*#8999*3825523# Don't Know.
*#8999*667# Debug Mode
*#92782# PhoneModel (Wap)
#*5737425# JAVA Mode
*#2255# Call List
*#232337# Bluetooth MAC Adress
*#5282837# Java Version
#*4773# Incremental Redundancy
#*7752# 8 PSK uplink capability bit
#*7785# Reset wakeup & RTK timer cariables/variables
#*1200# ????
#*7200# Tone Generator Mute
#*3888# BLUETOOTH Test mode
#*#8999*324# ??
#*7828# Task screen
#*5111# ??
#*#8377466# S/W Version & H/W Version
#*2562# Restarts Phone
#*2565# No Blocking? General Defense.
#*3353# General Defense, Code Erased.
#*3837# Phone Hangs on White screen
#*3849# Restarts Phone
#*3851# Restarts Phone
#*3876# Restarts Phone
#*7222# Operation Typ: (Class C GSM)
#*7224# !!! ERROR !!!
#*7252# Operation Typ: (Class B GPRS)
#*7271# CMD: (Not Available)
#*7274# CMD: (Not Available)
#*7337# Restarts Phone (Resets Wap Settings)
#*2787# CRTP ON/OFF
#*2886# AutoAnswer ON/OFF
#*3737# L1 AFC
#*5133# L1 HO Data
#*7288# GPRS Detached/Attached
#*7287# GPRS Attached
#*7666# White Screen
#*7693# Sleep Deactivate/Activate
#*7284# L1 HO Data
#*2256# Calibration info? (For CMD set DEBUGAUTONOMY in cihard.opt)
#*2286# Databattery
#*2527# GPRS switching set to (Class 4, 8, 9, 10)
#*2679# Copycat feature Activa/Deactivate
#*3940# External looptest 9600 bps
#*4263# Handsfree mode Activate/Deactivate
#*4700# Please use function 2637
#*7352# BVMC Reg value (LOW_SWTOFF, NOMINAL_SWTOFF)
#*2558# Time ON
#*3370# Same as 4700
#*3941# External looptest 115200 bps
#*5176# L1 Sleep
#*7462# SIM Phase
#*7983# Voltage/Freq
#*7986# Voltage
#*8466# Old Time
#*2255# Call Failed
#*5187# L1C2G trace Activate/Deactivate
#*5376# DELETE ALL SMS!!!!
#*6837# Official Software Version: (0003000016000702)
#*7524# KCGPRS: (FF FF FF FF FF FF FF FF 07)
#*7562# LOCI GPRS: (FF FF FF FF FF FF FF FF FF FF FF FE FF 01)
#*2337# Permanent Registration Beep
#*2474# Charging Duration
#*2834# Audio Path (Handsfree)
#*3270# DCS Support Activate/Deactivate
#*3282# Data Activate/Deactivate
#*3476# EGSM Activate/Deactivate
#*3676# FORMAT FLASH VOLUME!!!
#*4760# GSM Activate/Deactivate
#*4864# White Screen
#*5171# L1P1
#*5172# L1P2
#*5173# L1P3
#*7326# Accessory
#*7683# Sleep variable
#*8465# Time in L1
#*2252# Current CAL
#*2836# AVDDSS Management Activate/Deactivate
#*3877# Dump of SPY trace
#*7728# RSAV
#*2677# Same as 4700
#*3797# Blinks 3D030300 in RED
#*3728# Time 2 Decod
#*3725# B4 last off
#*7372# Resetting the time to DPB variables
#*7732# Packet flow context bit Activate/Deactivate
#*6833# New uplink establishment Activate/Deactivate
#*3273# EGPRS multislot (Class 4, 8, 9, 10)
#*7722# RLC bitmap compression Activate/Deactivate
#*2351# Blinks 1347E201 in RED
Posted on Dec 27, 2014
yxvvhrxt
Shan
  • 3 Answers
SOURCE: Where can I find a user manual for a Samsung Galaxy S5, SM-G900F?
You can find download manual for galaxy s5 plus on android lollipop form here
Androids DNA
Posted on May 04, 2015
terrellvaugh
Terrell vaughn
SOURCE: hello I bought a second hand
Can you help me with that to
Posted on Nov 12, 2015
How do I unlock a AT&T SM-870A for free?
How to Unlock Samsung Galaxy S5 Active SM-G870A AT&T
-Dial *#06# to find AT&T Samsung Galaxy S5 Active SM-G870A IMEI number
-Go to www.unlockninja.com
-Select Brand as:- Samsung
-Select Model as:- SM-G870A
-Select country: from where you purchased the phone
-Select network:- Locked network
-Enter Mail ID:-
-Update IMEI by following the login details:-
-get the AT&T Samsung Galaxy S5 Active SM-G870A Unlock Code at your email address with in 2-3 business days.
Steps to Enter AT&T Samsung Galaxy S5 Active SM-G870A Unlock Code
-Insert un-accepted SIM in AT&T Samsung Galaxy S5 Active SM-G870A phone.
-Turn on the AT&T Samsung Galaxy S5 Active SM-G870A phone.
-it will show Unlock Code screen.
-Enter Unlock Code and then press unlock
-Phone will be unlocked for ever to use any network
Feb 16, 2018 | AT&T Cell Phones
How to unlock reactivation lock galaxy s5 sm-g900a or is it possible
you need to remove the google account and the Samsung account from your device first, after this the react lock should be disabled
http://theandroiddoctor.com/samsung-account-removal-service-for-at-t-samsung-galaxy-s5-sm-g900a/
Try this link and follow the instructions.
Mar 29, 2017 | Samsung Galaxy Cell Phones
I updated the software yesterday on my S5 SM-G900H now after finishing the update my phone doesn't accept my pattern to open the screen.
Unfortunately it must have been a glitch in the software update which could've been caused by a virus \. The only way to fix the situation is by taking your phone to technician and let them remove the software you installed and they will delete the uploaded software and reinstall the original android firmware
Sep 20, 2016 | Samsung Galaxy S5
I lost my samsung galaxy s5 on last friday the 7th of july 2016 can i find it?
Jan, Links below tell and show how to find your Galaxy 5. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Find Lost Galaxy S5
Samsung Galaxy S5 Track If Lost Or Stolen
http://recomhub.com/blog/how-to-find-a-lost-or-stolen-samsung-galaxy-s5
How To Track Your Lost Android Phone Without Tracking App
Jul 14, 2016 | Samsung Cell Phones
How do I turn off the screen lock on my Samsung Galaxy E5
Andy, Follow steps below to turn screen lock off.
  1. Touch apps,
  2. Touch settings
  3. Scroll to and touch lock screen
  4. Touch screen lock
  5. enter your password
  6. Touch continue
  7. Touch none
  8. Screen lock has been turned off Check the attached links,instruction and guides, Good luck
How to turn off the screen lock on my Samsung Galaxy S5
How to Easily Master Format SAMSUNG GALAXY E5 SM E500 SM E500H SM E500HQ...
Apr 10, 2016 | Samsung Cell Phones
What is the imei unlock code for free
unfortunately if you have a phone account that is locked into a specific provider , the only way to unlock that contract is to pay the opt out fee
you may get a phone cheaper that is not locked into a provider
Oct 13, 2015 | Samsung Galaxy S5 SM-G900A 4G LTE 16GB...
Samsung Galaxy S GTI9000 Smartphone Logo
54 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
John Tripp
John Tripp
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
