Question about Lexmark X Office Equipment & Supplies
Why Not pulling the paper thru ???????? - X Lexmark Office Equipment & Supplies
I can not get the paper to feed in my Unisonic XL-1149 calculator
Cut paper at a 45 degree angle and load into back slot with angle (apex) of paper to the right of machine when facing it. Be sure to push it thru when loading. You should see tip next to calculator number wheel. Hit the additon sign several times to advance. You may need tweezers to pull paper thru if it doesn't advance by itself.
try this otherwise see the manual and make sure you are not using generic paper roll only use specific paper because the Chinese knock off paper is to thin
Mar 01, 2018 | The Office Equipment & Supplies
Can't print pictures from my laptop. The printer always says paper jam but there isn't one
"Paper Jam" issues are common with printers. They most often occur right after there has been a paper jam. Most people (not necessarily YOU), don't take the time to read how to properly clear a paper jam in their printers and often yank the jammed sheets backward thru the paper tray. Most times you should remove the cover in the back and pull the jam FORWARD out the rear, or if the jam made it close to the output tray, then FORWARD thru to the output tray. Pull sheets backward can cause two issues. It makes tearing the paper easier. This can result in tiny pieces being caught in places where the printer detect them as a jam. The other issue is that pulling backward can damage the feed rollers that pull the paper into the machine, as well as the mechanical sensors that detect paper jams. If you cannot find ANY shards of paper in the machine, you may have printer damage that results in the jam indication.
Oct 10, 2015 | HP Computers & Internet
Mp499 The paper tries to go thru but only one side pulls it and it goes sideways and gets jammed.
The feed wheels on the one side are either worn out or have some scrap paper stuck on them. Take a good look , after removing the paper tray, if it has one , inside the machine. It might be possible to turn the machine around and see into it from behind, if there is an access door on the back.
Aug 02, 2014 | Canon Office Equipment & Supplies
Paper pulls to right side and then jams it all started when paper jam i pulled it out and ever since then when loading paper it pulls to the right and then jams
Try running a good sized thickness paper thru it to clear out the cutters.
Sometimes when they jam some residual paper is left in the space between the cutter wheels and causes the paper to feed askew...
I use the cover from old phone books.
Sep 29, 2011 | Office Equipment & Supplies
Printer pulls one page all the way thru w/o printing anything on paper and then pulls 3 to 5 pages all the way thru and then 1 page thru and paper gets stuck in middle...then red light comes on and blinks...
check for low ink level it need to replace the color or the black cartridge click on the printer status to see what cartridge is near empty, or you can check for pending job right click on the printer then open it if you can see that it has a pending job delete it all
Aug 09, 2011 | HP Photosmart 7450 InkJet Printer
Paper not pulling thru in tray 2 creating a jam message
IF its pulling multiple pages its a seperation pad if its not pulling at all its the pick up rollers.
Mar 26, 2009 | HP LaserJet 4050n Printer
Paper feds but does not stay alligned. It crinkles paper and pulls it to the right.
something seems to be wrong with the rollers that pull the paper thru. probably one side pulls faster that the other or the other does not pull at all. I recomend you take the printer and get it repaired at the service.
Feb 22, 2009 | Lexmark JetPrinter X1185 All-In-One InkJet
How do you load paper into the printing calculator?
Oct 10, 2008 | Canon P23-DHV Calculator
'paper jam' error on canon pixma ip4300
ring canon support on 0844 369 0100
or try
support.canon-europe.com
they suggested i do a roller cleaning - but i cant find this option ?
Jun 24, 2008 | Office Equipment & Supplies
Shredding no more
if the unit is pulling paper thru but not shredding your cutters have separated for some reason. If not pulling paper thru but machine is running you probally have a broken gear causing cutters to no longer turn you may hear a clunking or grinding noise or gear may be stripped if shredder sounds like it is spinning freely. Contact manufacturer for parts availability.
Nov 26, 2007 | Royal CIA 12X Shredder
50 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
