On connecting my Thorens turntable to an Amp I am not getting a signal to one of my speakers although in mono they both work -but the sound lacks bass. Is it the cartridge?
richard vreede
    Sergeant:
  • 432 Answers
Since it lacks base i for sure know answer one is right
Posted on Aug 22, 2014
5 Related Answers
Anonymous
  • 515 Answers
SOURCE: very low audio output
Make sure your receiver has a PHONO input. If you are connecting it to a LINE or AUX input, then there is not enough signal to boost the sound coming from the turntable. Turntables require a PHONO input, because phono input's have a pre-amp on them, which boost the turntable signal. If you do not have a PHONO input on your receiver, you will need to buy a Phono Pre-Amp.
If you have a phono input, then you might have an issue with the turntable's RCA cables, or your cartridge may be at fault.
- TWEAK AV LAV
Posted on Nov 22, 2007
Anonymous
SOURCE: Low volume on PS LX250h
This turntable has a built in pre-amp, under the platter is a on-off switch. Turn it to "on".
-Former PS-LX250H owner
Posted on Jan 05, 2009
Verne Koti
  • 476 Answers
SOURCE: cant get sound out of speakers when connected to my ion usb turnt
How exactly have you got this equipment set up thanks ???
If you play another song on the computer from a cd original then what sort of output do you have???
Is the sound clear and complete???Bass Treble Mids etc
If the turn table has been set up properly the you will get a signal from the record deck to the computer and head phones too via the mixer.
Next is to check the way sound gets from the usb to the computer
Maybe the USB drivers are required for the computer before it will play correctly.
Try to uninstall then reboot and reinstall.Check again
If this doesnt work then try the make and model of the usb turntable and check to see if there is an updated driver for you computers type or brand or Operating System.ie - XP or Vista
Hope this helps ,let me know if you need more help,
Misterdj
Posted on Jan 19, 2009
Anonymous
  • 124 Answers
SOURCE: Record player - sound only plays out of one speaker
Your tracking and anti-skate are not set correctly.
If you have the manual for this unit, it should have directions for setting these.
Posted on Sep 12, 2009
Anonymous
SOURCE: Have a B&O RX-2 with mcc4 and loud hum
Maybe your turntable is too close to your speakers causing feedback
Posted on Feb 26, 2010
How can I connect a Thorens 145 turntable to it?
Your Harman Kardon AVR 85 doesn't have "phono" inputs. That means that you can not connect a turntable to it directly. You will need a "phono preamp" to amplify the very tiny signal from the phono cart enough for the HK receiver to play it. Something like this:
PYLE PRO PP444 Ultra Compact Phono Turntable Preamp
will do it. There are certainly better ones, like:
Amazon com TCC TC 750 BLACK Audiophile Phono Preamp Pre amp Preamplifier...
Feb 23, 2016 | Harman Kardon AVR 85
Thorens volume issue
You probably need to get a magnetic cartridge preamp to make it work. This will connect between the two.
Feb 06, 2014 | Audio Players & Recorders
Low volume from my thorens td-145 record player
Have you checked the cartridge in the turntable arm?Also check to make sure receiver/tuner is switched to Phono or Aux..Also check to see if there is a speaker switch on receiver.
Mar 07, 2010 | Thorens TD-170 Turntable
The volume is extremely low and there is no volume control on the player, how can I get a louder output?
use a PRE-AMP or connect it to the PHONO input of an amp.
You didnt sa what it was connected to ???
Tried to hook up turntable to Amp and will not produce any sound. What am I doing wrong?
The most common cause of this is due to the lack of a phono input. The inputs on modern amps/receivers are line level. Turntables produce a lower signal level requiring a phono pre-amp to get to line level. Purchase a phono pre-amp and connect it between the turntable and the amp. That should resolve the problem.
Dan
Dec 03, 2009 | RCA Audio Players & Recorders
Lack of signal to amp on turntable
You need to get a pre amp for your turntable. The 5740 does not have one built in. Not to worry, they are actually inexpensive! Google pre amp or turntable pre amp & you will find lots of good units that will do the trick for 25-45. They also give you an input ground to get rid of that lovely turntable humm. Hope this helps
Jun 24, 2009 | Yamaha HTR-5740 Receiver
Is there a way to plug a turntable into the ck - 1000? I was only able to get mono sound using a preamp.
You might have to buy a phono pre amp , just plug the t/table into the p/amp and then plug the p/amp into your CK
May 28, 2009 | American Audio CK-1000
Thump or thud coming from speakers when turntable is tapped
Just wondering how close your speakers are to your tables.Could be the tables pick up the low from the speakers.
Feb 23, 2009 | Technics SL-1200MK5 Turntable
STANTON STR8-150 Sound levels
try different rca leads to amp
Jun 01, 2008 | Stanton STR8-150 Turntable
50 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
