The leak is probably from the small PVC water line leading to the freezer door ice/water dispenser. Manufacturers put a small plastic joiner at that point to allow removal of the door for shipping and installation. That tiny connector can become easily disconnected and leak water onto the floor every time someone presses the water valve in the dispenser. It's easy to fix, Lowes and Home Depot have the fix-it kit for about $5, but you will probably find the existing joiner parts already attached but only needing to be rejoined.
I'll attach a photo of the Home Depot kit. you can also order it from Amazon and have it delivered right to your mailbox. Search for a "refrigerator door water line connector" and you should see a GE part number WR02X11330.
SOURCE: Ice build up on bottom of freezer
remove back panel inside freezer. you will see drain tray at bottom with a drain hole in the middle - this is blocked usually with ice. melt off with a hairdryer and follow up with hot water till water flows away freely
SOURCE: ICE BUILD UP ON THE BOTTOM OF MY FREEZER BELOW THE LAST TRAY
clear ice and with hot water pour into the drain hole till open and drains ,, take back panel of freezer out and wrap a piece of thick cooper wire around the heater and drop into the drain hold about 1in and it will keep drain open / thanks
SOURCE: side by side leaks out front door on freezer side
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
SOURCE: Ice build up on bottom of freezer. Water leaks out.
Your problem is possibly one of two things. The ice maker is leaking or the defrost tray behind the rear panel inside freezer back wall is clogged with ice or something else. If you know its not the ice maker unplug the refrigerator and remove the back panel to see if the drain is blocked there, Let me know, Sea Breeze
SOURCE: Leaking water and ice build-up in freezer
There's a drain hole in the freezer side behind the bottom drawer in the back wall that must be clogh ; put hot water into it untill melted the ice and keep pouring water to clean the drain (don't worry , the water goes to an evaporative tray) .Keep the drain clean by putting every 3/4 months half a cup of clorox or bleach.
