Thermostat wiring 4 wires one is blue
Blue is common. never let that wire touch any other color or you will short the transformer. Use a thermostat for single stage gas heat. R=Red W=White Y=Yellow which should go to the outdoor ac contactor and C=Blue which should also go to the outdoor ac contactor. If in doubt call a qualified Heating contractor to help you install. It can get quite expensive letting the smoke out of your parts.
SOURCE: thermostat wiring goodman model aruf032-ooa-1b
is this a heat pump or straight cool with heat strips?
SOURCE: I have a DuoTherm BriskAIr 13.5K BTU. The Dometic
If you look at control box at roof unit, they usually use a separate set of wires for furnace. See what colors they are attached to at harness to thermostat. Some just follow other harness, and come out at thermostat. (bypass control box) Once you've determined which 2 they are, join them together & see if furnace starts, as it should. If it does, thermostat is faulty. If not, pull outside cover off & check voltages at furnace. I'm guessing by furnace model that your unit is approx 30 ft , but if it's a park model, you may have 24 volt system on furnace or 12 volt. Another way of confirming is to go to back of furnace where air intake grille is inside your unit, and locate 2 blue wires going to furnace & remove whatever wires are attached to them & connect them together. Furnace should start up.
Testimonial: "thanks for the link. info solved my problem."
SOURCE: Trying to wire RUUD gas furnace. connection block
No problem have done this many times. R from the t-stat goes to R on the indoor unit. G goes to G Y goes to Y and C goes to C if you have a C or the t-stat the you are using. If there is no C there dont worry about it. It only need to be hookup if the t-stat uses power from the unit to run. Many t-stats today use battery power and do not need the C wire hooked up. Now R and C from the outdoor unit. R goes to the Y on the indoor unit and C goes to C on the indoor unit. That means that you may have two wires under the Y terminal and sometimes under the C terminal on the indoor unit. If on the outdoor unit there is no designation of R and C dont worry, just hook one wire to each of the two wires there for your low voltage connection. It does not matter which one goes to which unless they are marked then it may matter.
This should get you up and running and see it really isn't that hard!! :-)
Testimonial: "Thank you very much! I have been searching the inernet for hours to find a manual or diagram. Got a response within 15 minutes of posting. "
SOURCE: I have a Rheem Gas Furnace with an old analog
if you have 2 wire at thermostat Terminals at furnace that the thermostat wire attach to should be R & W if your new thermostat has R & W terminals is should work, an easy thing to remember is the red wire on R the white wire on W. If 4 wire at thermostat at furnace green on G, Blue on Y, red on R,and white on W same at thermostat If these do not match find a thermostat with these terminals
SOURCE: Carrier Infinity Control Thermostat SYSTXCCUID01-B
Your old stat is wired for a traditional thermostat and not a communication stat like the new infinity you have. There is a module plug on the furnace board that will need to be connected to the new thermostat for it to work. The wires that are wired now are from a terminal strip inside the furnace. Please contact your local Carrier dealer. They may be able to get that harness for you
