Question about Motorola Radius Cp200 - Two-way Radio Uhf 4ch Cp 200
My radio (new) receives but will not transmit, should I return it?
John L radiodude365
    Master:
  • Motorola Master
  • 570 Answers
Most simple answer, it is the programming. :) Have them reprogrammed.
Posted on Apr 13, 2015
Motorola Mobility
  • Official Brand Answer
  • 3,100 Answers
Contact Motorola Solutions or the original point of purchase.
Get Support
Mark
Motorola Mobility Support
Posted on Apr 11, 2015
Joram Nixon Mburi
    New Friend:
The PA must be out.
Posted on Apr 10, 2015
Thomas Beaver
  • 2,119 Answers
That depends on you. Are you happy that you received a device that isn't fully functional?
Posted on Aug 21, 2014
2 Related Answers
AngellXP
Angell XP
  • 27 Answers
SOURCE: One radio doesn't transmit voice
I think there defective. I'd return them.
Posted on Nov 15, 2007
Susan Wolding
  • 43 Answers
SOURCE: T5100 : One radio receive but not transmit back.
check batteries, maybe they are on the way out. otherwise its in the lever connection. old?
Posted on May 07, 2012
I have a Uniden UHF CB Handheld Model # UH076SX-NB. Have had it for 3 years and only used a dozen times. Now I can receive but unable to transmit. Any solutions please?
How do you know that the radio does not transmit? The batteries need to be fully charged, or new to transmit. The radio is old, and the cost to repair it may be close to how much a new CB radio is.
Good luck.
Aug 25, 2016 | Uniden Radio Communications
How to fix cobra 29 lx that will receive but not transmit?
your final could be blown,thus no transmit . if you change it make sure you change the driver also and retune that portion of the radio.
Jan 17, 2013 | Cobra 29 Lx Full-featured Cb Radio
On my Cobra 25 LTD CLassic, New my meter drops when transmitting
is this a new out of the box radio?if so you might need a tech to look at it because it could be an internal problem.It would have to be put on an analyzer and a scope to actually be seen doing what you say.don't worry because it can be fixed.the cost of fixing it is the problem.You have to decide whether you want to pay more for the repair than you paid for the radio. Either way,new or used the answer is the same.
Sep 30, 2012 | Cobra 25 LTD 40-Channel CB Radio
I have a new cobra 148 with ssb, about 6 months old, while i was away there was a storm, now the radio doesnt work , recieve or transmit, i also have a cobra 29 ltd that wont transmit but it will recieve....
make sure the mic is good. If for some reason the mic went bad, it will not receive or transmit.
As for the one with no receive, it most likely needs a new final.
If lightning hit your antron, it would be in pieces.
Aug 02, 2010 | Cobra 148 GTL 120-Channels Base CB Radio
Motorola T5420 Transmit Problem
Here are some troubleshooting thoughts:
1. Is your battery indicator showing at least 2-3 bars? (Battery Note: Your rechargeable batteries may fail due to setting without use for a long period of time. They need replaced every 12-14 months usually. A good tip is to charge them once a month to keep the chemical in the battery active.)
2. Check to see your Qt noise filter is shut off. Refer to page 22 of the owners manual. It is possible you have some radios set to Y and others to N. To assure good communications you should set all of them to N.
3. With your radios set to interference code zero, place your radios one at a time in scan mode, while you transmit/talk on one individual radio. See if any of the radios receive. Do this with each radio individually to see if you are transmitting at all. NOTE: This test will determine if you have any ability to transmit. If you do not receive any sound on the 3 radios setting in scan mode, the individual radio you are testing will not transmit.
Aug 25, 2008 | Motorola Talkabout T5420 (14 Channels)...
Doesn't work
I was abel to make mine work I put one on chanel 20 then scanned with the other and pressed the ptt button on the unit on channel 20 until scanned one found transmition.
Dec 25, 2007 | BellSouth 2250BK (22 Channels) 2-Way Radio
Motorola Radius Cp200 - Two-way Radio Uhf 4ch Cp 200 Logo
212 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Muntejaya Ginting
Muntejaya Ginting
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
