Question about APC Smart-UPS RT 10000VA - UPS ( external ) - AC 220/230/240 V - 10000 VA - Ethernet 10/100 - 8 Outp... UPS System
Apc smart ups rt 10000 internal fault, what to look for?
David Wiebe
  • 11 Answers
We had the internal fault light indicated and APC told us it was an internal fan fault and the UPS would need to be repaired or replaced.
Instead we tested the battery banks and one was totally dead. Replaced that battery bank and the UPS is working again.
Note: The battery fault was NOT lit, only the big "X" which indicates an internal fault. So check your batteries - even if it doesn't indicate that the batteries are faulty!! There are eight 12v batteries (WP5-12) in the bank which ends up being a bit over 100 volts per bank.
Posted on Jan 09, 2017
Sami Sawda
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 65 Answers
You should check the inverter and the charger boards as well.
Mainly IGBTs and drivers (IGBT drivers).
better locate the fault and replace the defective board
Posted on Jan 13, 2015
5 Related Answers
Anonymous
SOURCE: APC Smart-UPS RT 1000VA
Hello Dear Specialists I have a problem with the APC Smart-UPS smart 1000VA: when I insert the
power plug in the wall outlet in one ups , indicate the AVR Boost ups regulating low AC voltage, when I measuring the AC city power voltage that is 207v .whey this ups is not working about the AC low voltage? ,but it should be work from (170v ~ 230v) AC input volte.please solve this problem, which element of AVR from the ups is failed or wrong and give me free circuit diagram low & high AVR and charger and inverter circuits. thanks allot
Posted on Jun 17, 2009
Jesrey Paco-in
  • 91 Answers
SOURCE: APC smart ups 1000va
Here we go again.. i encouter a lot of this problem. just change the whole front panel board and everything will work fine.
Posted on Aug 14, 2009
SOURCE: how to connect a UPS to a computer? why some UPS
A UPS goes between the Power Socket and the PC equipment.
So ya can "Talk" to the UPS and change monitor settings. So do some don't depends wat ya want?
A "Smart" one is computer controlled, and most probably ya can "Talk" to it, the other is the "Vanilla" model, real plain.
More Complex.
Posted on Jan 26, 2010
Anonymous
  • 25 Answers
SOURCE: APC smart UPS
Check mosfet.
Posted on Mar 09, 2010
dadangandara
Dean Arhafidzia
  • 42 Answers
SOURCE: Could you tell me how many batteries a matrix UPS
Battery 48V 17Ah smartcell, CT formation
Posted on Aug 27, 2012
Apc smart ups rt 10000 internal fault, what will cause it?
if you can give me the source code I can tell you. the code is going to be in the form of zero's and one's
Aug 21, 2014 | APC Smart-UPS RT 10000VA - UPS ( external...
UPS SURTD5000XLIQ is being powered but indicating red Led fault , What may be the cause ?
it is cause by UPS internal fault, possibilities like faulty charging circuit, inverter, etc.. you can call APC and check if its still have warranty, APC will replace it right away :D
Dec 27, 2012 | APC Smart-UPS RT 5000VA (SURTD5000XLI) UPS...
Inverter fault
This unit will require you to Brain dead the whole UPS.
To see if it is actually a condition that exists with the hardware or if it was just a lock condition.
Steps:
1)Power down unit completely
2)Unplug all batteries
3)Unplug from wall
4)Leave unplugged for about 5 minutes or so WITH NO POWER AT ALL.
5)Plug batteries back in
6)Plug back into wall
7) Turn unit back on
Log into console of UPS and see if the condition returns.
If it does not return your good to go.
If the error returns. You have to replace the WHOLE battery pack.
APC has told me their units are typically good for 4-6 years, after that their units cannot hold the same tolerances as they did when they were brand new.
Hope this helps.
Oct 30, 2012 | APC SURT8000XLT-1TF3 Smart-UPS RT 8000VA -...
Apc smart 1000 ups after changing batteries all right are blinking
Is this the RT or the VT or the RM or the XL? Recheck the UPS's batteries by conducting a battery test. Press the I/Test button to initiate the battery test. If All LED are lit and the UPS emits a constant beeping then there is a internal fault.
FRONT PANEL LEDS FLASH SEQUENTIALLY: The UPS has been shut down remotely through software or an optional accessory card.
If all else fails then remove the input power. Unplug the batteries. Check the fuses in the back. If fuses are ok then push and hold the power button. This will reset the logic. Plug batteries back in, apply power and hopefully all is ok. If not then purchase another UPS the cost to repair it will be more then what it's worth
Sep 20, 2011 | APC Smart-UPS 1000VA UPS System
Continous beeping and no led's are lit
Basically for SURT models it should have an internal fault if you get that kind of symptoms. One (1) diode is already opened which is always a problem of this APC SURT series. you need to open the unit and do further troubleshooting or send it to APC service center in you area or APC service partner. if it still under warranty you can call APC call center and get a replacement unit. you just need the exact model and Serial number of the unit.
Aug 07, 2009 | APC Smart-UPS RT 3000VA UPS System
Charging apc 800va through home generators
The reason of this is the UPS cannot adopt on the frequency that is being generated by your home generator. you should use APC smart ups series coz smart-up series can work on a wider input frequency range.
Jul 27, 2009 | APC Smart-UPS RT 8000VA (0731304239635)...
Apc smart ups 1000va does not work propery. when i switch on they make noise continuous so how can u help me plse.
UPS has an internal fault, ask APC to replace it if there still have a warranty or send it to service center for repair
Apr 29, 2009 | APC Smart-UPS 1000VA UPS System
Aug 20, 2008 | APC Smart-UPS 1000VA UPS System
APC Smart-UPS RT 10000VA - UPS ( external ) - AC 220/230/240 V - 10000 VA - Ethernet 10/100 - 8 Outp... UPS System Logo
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Joe Goldman
Joe Goldman
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
