Acer Iconia A50010S16u Tablet Computer Logo
A
Anonymous Posted on Aug 21, 2014
Tablet wont charge
Power jack wont start charging the tablet can you use usb port
Aneudy Meran
Level 1:
New Friend:
  • Contributor 25 Answers
  • Posted on Aug 21, 2014
Aneudy Meran
Contributor
Level 1:
New Friend:
Answers
25
Questions
Helped
7903
Points
56
Unfortunately Acer tables use a 12volt voltage. On eBay you can find replacement But make sure that the charging port is working.
4 Related Answers
Anonymous
  • 104 Answers
  • Posted on Mar 20, 2008
SOURCE: Acer 3690
It could be the cord, if it is frequently bent right at the connector the wires inside can be broken. You can obtain a replacement plug that can be soldered onto the wires from RadioShack. you'll need to cut the old plug off, about an inch from the connector to make sure you eliminate the bad part of the wire. You must be sure to get the polarity of the plug correct or you can damage the PC or the battery. The power pack may have a diagram with the polarity.
It could also be the power jack on the PC itself. With frequent use the jack solder joints could have cracked and are no longer making a connection. They can be re-soldered to correct the problem, but it is a tedious task to take it apart to get to it.
If you have a MultiMeter, Analog or Digital (DMM) you can use it to test the power pack for output, as well as use it to determine the polarity. With the meter connected you can bend the wire to see if it breaks the power connection, if it does you just need to replace the plug.
Hope this helps :)
Anonymous
  • 89 Answers
  • Posted on Nov 25, 2009
SOURCE: Is there any way to charge an ACER computer
No im afraid this is impossible.
Anonymous
  • 808 Answers
  • Posted on Jul 29, 2010
SOURCE: was charging aspire 3680 when it started smelling
Its may the problem of ur charger or may be the provlem of ur battery
Anonymous
  • Posted on Mar 27, 2012
SOURCE: charging
MY ACER TABLET DOES NOT WANT TO GET UNLOCK AND THE CHARGER ALSO WHAT CAN I DO ABOUT THAT.. [email protected] IS MY EMAIL
1helpful
The charge dock on tablet broke so we can not charge tablet can it be fixed? We just got it this October.
Juello. Did some research on your tablet at Amazon, (http://amzn.to/1xWx6S5) and see that they also have an AC charger (AC charger adapter with a 3.5mm power jack and delivering 5VDC 2A). Available for $5: iRulu Black AC Home Wall Adapter Cable Charger for Tablet PC 5V 2000mAh or a there's a nice replacement KB and cover: iRulu New Portable 10 1 10 5 Android Tablet USB Keyboard Case Black . I would guess the connector snapped off inside the tablet, so you will have to remove it with some tweezers. If the pin for the AC adapter broke off inside the tablet, that's a problem, but most everything can be charged from the USB port too see this website:
How To Charge Samsung Galaxy Tab 2 Via USB Port On Computer Laptop PCNEXUS (Samsung used as an example). GL
2answers
Tablet won't charge
Your charging port (where you jack in the USB to the samsung tab) but first try another Samsung USB plug and flex
Why wont my zeepad turn on
Check the battery is charged - it may be duff and nee replaced if it is not charging or your power adaptor may not be charging it - check it with a multimeter - the power socket on laptops andf tablets are very susceptible to damage - if that fails then plug it into a pc using the usb port - it will charge very slowly as usb only has a very low charge current but be patient and if it charges up after 12 hours using the usb method you will know one way or another whether its the battery or the power socket or charger.
Why wont the tablet fully power on
Check the battery is charged - it may be duff and nee replaced if it is not charging or your power adaptor may not be charging it - check it with a multimeter - the power socket on laptops and tablets are very susceptible to damage - if that fails then plug it into a pc using the usb port - it will charge very slowly as usb only has a very low charge current but be patient and if it charges up after 12 hours using the usb method you will know one way or another whether its the battery or the power socket or charger.
Or do you mean you are stuck at the boot screen?
You will need to give more info.
Battery won't charge
Yes it will :)
If you are using a USB port on a PC or Laptop think of trying a different USB port - sometimes they put out low power;
If your laptop or PC is more than 3 years old it probably can not put out enough power on the USB to charge a tablet (any tablet).
Check to see if any of your existing wall adaptors for (say) your phones have the same micro USB connection - use it to charge your Kindle - it's totally fine.
Go to any shop in the high street and buy a Micro USB wall adaptor, they start at about 5gbp. You can get them on Amazon too.
Remember it takes about 6 hours to charge from the wall and 16 hours (yes, 16) to charge from a computer usb.
Good luck
Kindle isnt charging
Yes it will :)
Good luck
My coby Kryos tablet does not charge
i keep charging it but the light will not come on and when i press power it still wont come on
1helpful
Repair charging port on google nexus 7
yes.
The micro usb charging port on the nexus 7 is notorious for becoming useless b/c cords fit loosely in the port right out of the box. Micro usb cords get wiggled and jiggled because of the size of the opening and then the port will no longer charge b/c solder breaks from the board, or the tongue inside the port partially breaks apart.
You can buy the replacement micro usb / headphone jack assembly for about $50 and do the repair yourself (hopefully) ...or you can send it to us and we\'ll replace just the jack and ship it back to you all for $54.95
More info and our repair form is on this page:
http://www.rockhoptec.com/services.php#t...
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
