Canon Pixma MG5220 InkJet Printer Logo
A
Anonymous Posted on Aug 20, 2014
I get an error message
Error message 6A81.. Doesn't work at all
1 Related Answer
F Victor man
Victorman
  • 846 Answers
  • Posted on Jun 04, 2011
SOURCE: the error 6A81 comes up
This is a purge unit error. There maybe something jamming the purge unit or just a absorber out of place which is picking up on the carriage preventing it from moving correctly. if you can move the carriage away from the purge (its where the printhead/carriage parks its self on the right side of the machine) with no resistance then you can shine a torch into the machine and look at the purge unit. there maybe crumpled paper jammed in the purge. If all looks well then the purge may need replacing. Lastly the wiper on the purge may have stuck. It slides back and forth and they have been known to stick. just push it with a long screwdriver to see it it moves.
Good luck
2answers
Print error 6A81 how can i find out wot to do
You did not say what type of printer it is, or if you have checked for a piece of paper stuck somewhere in the printer.
Example of possible solution:
https://www.inkredible.co.uk/canon-error-code-6a81-fixed
Quoting from web page shown, photo not included in quote:
"Canon Error Code 6A81 - Fixed! We recently came across error code 6A81 on our Canon Pixma MG5250 Printer (using PGI-525/CLI-526 range cartridges). The error could also occur on other printers in this range.
The error code is basically caused by an obstruction within the printer, usually a paper jam but could be any foreign body that has found its way into the printer (those with young children will understand!). The obstruction stops the carriage and print head from moving into the correct position when powering up the printer. The print head should come to rest at the right hand side of the carriage and position itself over the waste ink sponges. If the print head is unable to do so, it returns the '6A81' error message.
You can see from the picture, the position of the two waste ink sponges towards the right hand side. The sponges are spring loaded and move backwards and forwards when the printer initialisation occurs upon start up.
The problem in our case was caused by two pieces of torn paper. One at the far right of the printer which was simple to remove, but the other was stuck in a small opening behind the spring mechanism for the waste ink sponges. This was preventing the sponges from being moved freely and seated correctly, which in turn meant that the print head was unable to pass over them and come to rest in the correct position.
To remove the torn paper we turned off the power to the printer (to prevent any damage to the carriage mechanism) and used a pair of tweezers to carefully pull the offending article through the small gap. We missed this hidden piece of paper the first time we checked for obstructions so it's worth shining a torch in and having a good nose around!
Close your printer lid, power on the printer and et voila... Canon error code 6A81 is no more!"
How can I fix an error msg #6A81 on the Pixma mg5320?
Error 6A81 is described here: http://www.canon.co.uk/support/consumer_products/product_ranges/printers/pixma/error_codes/#5011
Description
A printer error has occurred.
Resolution
  1. Turn off the machine and unplug the power cord from the power supply.
  2. Plug the machine back in and turn the power on.
    NOTE- If you disconnect the power plug, all the faxes stored in the machine's memory are deleted.
If the above solution has not resolved your error, please contact your nearest Canon authorised service facility.
5220 quit. says "turn off and on"-no fix. Says "see manual"-no info. Shows "6A81 on top of screen. Error Code?
6A81 means the carriage is blocked by something. Start by checking the following image to verify there are no paper jams.
http://ww2.justanswer.com/uploads/wa94sound/2012-04-25_230949_sdf.png
Reply back and let us know what you find.
Error 6a81
Turn off power, remove power cord and wait 10 minutes, then reconnect power cord and turn unit on, if this does not work then advised to contact canon service centre
old marine
old marine
ZJ Limited
ZJ Limited
