Seems to be leaking by the front engine compartment. Only after running the Air or Heat? Why is this happening? It does not leak when you do not run the air or heat and only leaks for a short period of time after stopping.
You do not say if you are losing coolant or not , if not every thing is ok as its condensation from the air con, If it has coolant loss it could be over heating, make sure the extra fan comes on with the air con.
Condenser is dirty, heat is not good. Condenser easily coated with dust and small insects, if not long-term clean-up, the condenser heat is not good, air conditioning and refrigeration effect will be decreased, the condenser can be cleaned by dirty water will approach, but be careful not to be too water pressure high condenser is quite fragile. You should check the car. Shenzhen Too Star Technology Co Ltd Home travel charger car charger
Check the color of the water coming from the engine. Is it clear or is it a different color. It the water has no color then it is just the normal condensation that the AC unit is removing from the air. If the leaking water is yellow or green, then it is actual coolant from the engine.
SOURCE: central air conditioning unit
you must do the maintenance . Call to the tech for to make the maintenance required. to due the activity of work.
God bless you
seals can swell or shrink from lack of use even stick
what probably happened is from siting it stuck to the shaft and by starting it caused it to tear
SOURCE: Audi coolant
check the overflow tank and take the radiator cap off (when it's cooled down). if there is radiator fluid in either or both of them, you could have a stuck thermostat or a bad water pump. check the thermostat first.
SOURCE: oil leak drips at the oil filter
Tighten the filter. If it can't be stopped, replace the filter.
SOURCE: can someone please show me where the air charge temperature sensor is located
It should be on inlet manifold somewhere between engine head and air filter
