Question about Konica Minolta DiMAGE E500 Digital Camera
Dimage e500 camera stopped functioning with lens extended, changed batteries, but still nothing happening (lens is still in out position) can you help ?
5 Related Answers
Anonymous
SOURCE: Dimage Z1 lens stuck
With the camera turned on and the lens extended gently bend the lens outward in three places and the lens assembly will come off. This allows access to the zoom assembly which is probably the part that is rattling as it slides the back lens along its shaft. You may want to let a professional do this for you. After you find the problem reverse the procedure to reattach it.
Posted on Dec 17, 2007
zohail
Shoaib Rais
  • 1223 Answers
SOURCE: Konica Minolta E500: The LCD screen has gone blank
are ur pics black if u see them on pc then
this is a BAD CCD problem thousands are facing dont worry konica will do it free of charge even if u are out of warranty and not on list, just call or contact KONICA see this PLS RATE ME FIXYAfor help
http://www.konicaminoltasupport.com/English.importantnotice_en.0.html
Posted on Apr 07, 2009
Anonymous
SOURCE: Dimage Z3 lens does not retract
Check your batteries. Are they working? Try taking them out and replacing them. If you left the camera on when you put it away and the batteries drained, you won't be able to retract the lense until fresh batteries are inserted and the camera is powered up again.
Posted on Apr 19, 2009
BillB-SA
Bill Buchsbaum
  • 2761 Answers
SOURCE: minolta dimage g400 camera...cannot get the lens to close
Your problem is likely due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may require professional repair.
Posted on Oct 20, 2009
Ty Price
  • 11967 Answers
SOURCE: Konica Minolta DIMAGE G600 getting System error S 0042 message
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Apr 20, 2010
Lens is stuck in the out position, can you help ?
yes it happens to me too.
please find the camera disassembly manual in pdf format or try youtube video.
then you can dissasemble cam and fix the stucked parts.
95 :/: is no damaged parts .you need to reassemble according to manual.
regards,
nuwan
Aug 20, 2014 | Konica Minolta DiMAGE E500 Digital Camera
Controls don't function
Can you set the time and date. Some require the time and date be set before proceeding.
Jun 21, 2008 | Konica Minolta DiMAGE G500 Digital Camera
Optio 555
Is the lens totally stuck? Does it even move a little? Did you try to power cycle the camera?
Feb 27, 2008 | Pentax Optio 555 Digital Camera
My digital camera KONOCA-MINOLTA dimage E500 need
Its possisble that you battery is exhaust or stay some memory charge there? They are NiCa or Ion Lithium?
Jun 28, 2011 | Konica Minolta DiMAGE E500 Digital Camera
Lens error
Please allow me to explain what a lens error is.
A lens error is when the units lens motor gets stuck into position and cannot retract or extend. The units motor is what pushes and retract the units lens in and out of the unit. When this motor is past its prime meaning about to become defective this is the result.
Here is the possible cause:
1. Dirt or debris in the lens housing.
2. The camera has been drop-ed or damaged.
3. Sticky substance got into the lens housing.
4. The motor has given out.
Here are some solutions to try before spending your hard earned money at a camera shop.
1. Take the battery out
2. If the lens is out try to gently push it back in.
3. Put the battery back into the camera and power it on.
Please do the above steps if those steps do not help please do not shoot the messenger. Please take it to a shop and have them give you a appraisal on the value of the camera and a estimate of what it would cost to fix.
In most cases it is worth the repair. Please get back with me if you have any questions or comments, Thank you for using Fixya.com "we have solutions for everything"
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Oct 29, 2010 | Konica Minolta DiMAGE E500 Digital Camera
When i put a new battery on my dimage e500, it still doesnt turn on, why is that?
sometimes the battery is damaged.other wise the chip set in your camera is damaged.
Jul 19, 2009 | Konica Minolta DiMAGE E500 Digital Camera
Mar 23, 2009 | Konica Minolta DiMAGE E500 Digital Camera
Feb 02, 2009 | Konica Minolta DiMAGE Z3 Digital Camera
Dec 14, 2007 | Konica Minolta DiMAGE Z1 Digital Camera
Konica Minolta DiMAGE E500 Digital Camera Logo
Top Konica Minolta Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Steven Wander
Steven Wander
Marvin
Marvin
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
