Question about Weed Eater Fl26 Feather Lite Plus String Trimmer
HOW TO PUT IN LINE WEED EATER FEATHER LITE PLUS FL26?
Posted by DIANE JONES on
Lawrence Oravetz
  • Weed Eater Master
  • 10,548 Answers
You can get a manual from the Weed Eater website.
Posted on Aug 21, 2014
Where is the air adjustment screw located on a Feather Lite Fl 20C Weed Eater?
The adjustment screw on the feather lite can be flush in the carburetor but i do believe you'll need a special type screw driver to adjust that carburetor. I've seen some screws with splines on them and some with a slot. The air adjustment on that model is very finicky so take your time.
Jul 07, 2014 | Craftsman 25cc Gas Line Trimmer
How to change the fuel filter on a Weed Eater Feather Lite FX265Xtreme 25cc. The weed eater stars but won't run.
Use a hooked piece of wire to snag the filter through the fuel tank, it should pull off the fuel line.
Oct 12, 2011 | Husqvarna Forest & Garden 125c 17"...
25cc Weed Eater
Yes. any 2 cycle oil will do. It is right do not use marine oil it runs alot thicker than 2 cycle oil.
Jul 06, 2010 | Garden
Powerpro 17" McCollich weed eater
hey harry the float inside the carb is stuck i would suggest rebuilding the carb
Jun 27, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
I have a feather lite weed eater xt26 and it will
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please rate me, Thanks
Good Luck, I hope this helped
May 08, 2010 | Garden
Trimmer not getting gas
carburetor diaphrams are stuck. clean the carb and check the diaphrams to see if they are stiff.
May 02, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Trying to get my weed eater to start
I have been told not to but I use starting fluid to start mine. just one ir two short sprays.
Sep 27, 2009 | Garden
Weed Eater Fl26 Feather Lite Plus String Trimmer Logo
317 people viewed this question
Top Weed Eater Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
Are you a Weed Eater Garden Expert? Answer questions, earn points and help others
