I obtained Words with friends some time ago suddenly a message appeared stating that it had unexpectedly stopped working, I have deleted it and then downloaded it repeal with no luck. What is going on I am most frustrated and upset. Tried working with Kindle, they could not help. Can you help?
SOURCE: Kindle stopped working. When I
Apologies, this is not a solution, but just to say that I currently have exactly the same problem. Have you managed to fix yours?
SOURCE: 1. My kindle keeps freezing. 2. When not frozen,
I had the same thing happen to my kindle. I contacted amazon customer support and within the week they sent me a replacement kindle free of charge!
SOURCE: deleting old words with friends games on the ipad
Push and hold app until jiggliing with x.Tap x to delete from ipad.
SOURCE: kindle fire will not load words with friends
Step one, download advanced task killer. It works great. When down loaded set the security level in the app to "low", the kill level to "aggressive", and the app kill rate to "whenever screen is off". reset your Kindle. (turn completely off, then back on) Try using your games again if that doesnt work then u might reinstall a game or two and see if that makes a difference. My fire did the same thing to me. Alot of time apps will run in the background and eat all of the RAM (memory) up and when you try to run games there isnt enough to do so. I had the same problem trying to play jetpack joy ride
Hi Tina,
The problem could be a crashed or hung application. Depending on which version of iOS your running what you might want to try first is to see if the game is still running in the background;
Double click the bottom button on your iPad
Then you will see all the applications which are open
Close all applications just to be safe
Then try your game again.
If it still fails then after doing this turn the iPad off completely.
You do this by;
Pushing the power button (top right of the iPad) for 10 seconds
then slide the slider to Power Off. Let it shut down completely. After about 60 seconds turn the iPad and try your game again and see if it works.
If this still fails, you may have to check if the App Developer has released a newer version. But likely the previous solutions should resolve your problem.
Hope I was able to help
Philipp
First remove the app from your Amazon.com account, using your computer web browser to your apps page Select delete this app from the "Actions..." drop down menu to the right of the app. Then remove the app from the kindle Apps Library Device tab by pressing and hold the app you'd like to remove and tap remove from device After you have removed the app, please reset the kindle by pressing and holding the power button down for a full 30 seconds... Then wait a few seconds to turn the Kindle back on and allow to restart. Once the Kindle is on the home page make sure have a good wireless connection and may then go back into the app store , type in 'WORDS' and then select the Words with Friends app to reinstall on your Kindle Fire
