Question about Motorola Mobility Whisper Bluetooth Headset
My whisper seems to be muted no one can hear me
When I talk into my headset no one can hear me but I can hear them. If I try to adjust my headset the person on the call can hear me adjusting the headset. I checked to see if the phone was muted and it isn't. What can I do to get it working?
  • Motorola Mobility
    Motorola Mobility Aug 20, 2014
    Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? There is a mute option on your phone and your headset. have you confirmed you haven't muted the headset?
    Mark
    Motorola Support
  • Official Brand Answer
  • 3,100 Answers
Ensure that it isn't muted on headset and phone. Call us if you still have issues. Http://www.Motorola.com/contactus
Mark
Motorola Support
Posted on Aug 24, 2014
Anonymous
SOURCE:
Anonymous
SOURCE: MOTOROLA H800 WIRELESS HEADSET
I took mine apart to see what the problem was, the two wires that go to the mic had be broken. Probably by the sliding motion of the boom. Gonna try to fix it if i can..don't know, It will probably do the same thing again. Always remember- THE MORE MOVING PARTS TO SOMETHING THE MORE THERE IS THAT CAN GO WRONG!
Posted on May 16, 2009
Anonymous
SOURCE: H500 bluetooth headset
Turn down the volume on the PHONE, not the headset. Motorola 325i w/ H500. Again, turn down the volume on the PHONE, not the headset. In my case almost all the way down.
Posted on May 02, 2007
Anonymous
SOURCE: It's on but earphone not working
Solution number one does work. Just tried it and presto!!, all working again.
Posted on Jul 08, 2007
Anonymous
  • 4 Answers
SOURCE: does it have a mute button because person on phone
Tap both volume buttons to mute/unmut. If that does not solve it i have heard many accounts of these headsets having back mic's.
Posted on Jul 09, 2009
Anonymous
SOURCE: when i try to talk threw my headset the other
h710 is muted, but when I tap the volume buttons at the same time, I hear a beep or tone; however still stays muted
Posted on Feb 02, 2010
No one can hear me. I have the major volume adjustment set to "D" and the minor volume adjustment turned up a few notches, but i'm told I sound like I'm in an ocean. The configuration...
By having your microphone set to level D, try setting it on A while talking to someone who can here you while you switch through. Most systems are set to B for standard use. On the back of the unit is an up or down microphone, that would allow your voice to be made higher or lower.
Good luck from Headsets Direct - 800-914-7996.
Aug 16, 2011 | Plantronics Voyager 500A Deskphone Adapter...
Plantronics CS55. When using the wireless headset
Echo is usually caused by the transmit (speak) level on the unit being set too high.
1. First, try lowering the volume of the telephone. If you still hear an echo, adjust the volume of the headset itself.
2. The master transmit controls of the headset are the ABCD switch settings on the bottom of the base. A is the lowest and D is the highest setting.
3. You can fine tune this setting with the plus (+) and minus (-) buttons on the back of the charging base.
4. If this doesn't fix the echo, try moving the configuration dial on the left side of the charging base. The recommended setting for most phones is 1.
Jul 10, 2009 | Plantronics CS55/HL10 Wireless Office...
H700 headset person on the other end cannot hear me - I tried adjusting volumes - no use
Make sure that the tip is not resting on your cheek. That is were the microphone is in that pin hole, adjust the headset so that it stays off of your cheek
Jul 12, 2008 | Motorola Mobility H700 Wireless Headset
GN Netcom wireless headset volume adjustment
Transmit volume adjustment
Adjust the volume of transmitted sound according to personal preference.
To adjust the volume:
1. Make a telephone call and ask the person you are calling to assist
you.
2. Press the +/– buttons on the headset simultaneously for 2 seconds.
A beep will indicate when 2 seconds has passed.
3. Adjust the volume level by pressing the + or – button.
4. When the person you are speaking with fi nds the volume of your
voice appropriate, press the +/– buttons simultaneously for 2
seconds. This setting is now stored in the headset.
A Copy of the manual is avaliable at:
http://www.onedirect.es/files/GN%20Netcom-ES/GN%20Netcom%209120%20manual.pdf
You must have Adobe Reader to view it and the instructions are on page PDF page 3 or manual page 6. Adobe Reader is avaliable for download at:
http://www.adobe.com/products/acrobat/readstep2.html
May 21, 2008 | GN Netcom (9120-48) Wireless Headset
I can hear but person can't hear me
While talking, turn up your volume on the headset. If this does not help return your bluetooth for defective voice pickup censer.
Dec 07, 2007 | Motorola Mobility H350 Wireless Headset
Call just drops. I can hear but person I am talking to can not.
Nov 29, 2007 | Motorola Mobility H350 Wireless Headset
Buzzing
I would think that your mic part is shot or you need to adjust the volume of your mic. Go to Start---->Control Panel---->Sounds And Devices---->Volume----->Advanced now adjust your input mic levels a little lower.
Nov 05, 2007 | Creative Labs HS-400 Headset
H500 headset
are you pressing L3 to talk?
Aug 31, 2007 | Motorola Mobility H500 Wireless Headset
Motorola Mobility Whisper Bluetooth Headset Logo
709 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
