How do I extract the water, is it by connecting a hose to the external plug or is there an internal 'bucket' no manual and problem finding one
I was also unable to find a manual through any of my many searches, however either of these two links may provide some general, generic assistance, given similar items. Hopefully you may find something useful:
1) This website includes numerous general info articles. Link to Article Library & Buying Guides (for similar items):
http://www.air-conditioner-home.com/portable-ac-library/
2) YouTube video - Portable Air Conditioner from Air-Conditioner-Home.com:
https://www.youtube.com/watch?v=LRDihKbdrwc
SOURCE: APE08AK GE Portable Room Air Conditioner isn't draining
I had the same problem and unscrewed and removed the back cover (AFTER I UNPLUGED THE UNIT) and noticed there is a small black tube that the drain tube connects to. Mine was broken off track and I had to physically remove the small black tube, put it back in it's place and super glued new tabs along the side so it would tilk back and drain the water in the bucket vs. the floor via the unit.
Hope this helps.
SOURCE: Is there a drainage plug or hose on the air conditioner? It's leaking.
To increase the efficiency of the air conditioner's cooling to meet US energy requirements, most manufacturers eliminated the traditional drain plug. Instead, they switched to a design that used the extracted moisture from the room to help evaporatively cool the condenser.
To do this, the traditional fan blade was replaced with a 'sling blade' which was a fan blade with a rim or ring around it. The drain plug or drain hole in the bottom of the pan was eliminated and replaced with overflow notches in the back edge. Along with a solid piece drain pan, this provided a pool of water for the edge of the sling blade to dip into and pick up water to 'sling' or spray around the compartment to create evaporative cooling. The overflow notches established the maximum depth of the water pool and are also the lowest place when installed properly.
Although this is more efficient, this has caused 2 problems: increased noise as the water is slung around and water spray from the side air vents.
Persons have drilled holes through the pan or back edge as drains. This is not recommended as it negatively effects the colling ability of the unit and could lead to a voided warranty or premature failure.
Instead, insure that there is adequate pitch with the installation and make sure the overflow notches are kept clear.
If you 'need' a drain hose, my suggestion would be to drill into drain pan's back edge or the rear potions of the sides. The hole should be at the same level as the overflow notches. Once the drain hose is installed, block/cover the overflow notches to redirect the excess water to the drain hose instead.
SOURCE: We have a 9000 btu portable frigidare air
How high up is your exhaust hose in relation to the unit - if it is too hight, the pump may be struggling to discharge the water.
I assume this is a vented model, where you have a large diameter pip exhausting air outside (Around 110mm wide) if so, is there also a smaller pipe to carry the condensate water?
SOURCE: My portable frigidaire air conditioner bucket light on
The actual bucket is located inside the machine at the bottom. To access it, you must unscrew all of the screws and take the front panel off. You cannot empty it from this side so it is not worth taking the machine apart.
However, in order to empty the bucket, there is a small black plug at the bottom left hand side at the rear of the machine. Be careful when pulling out the plug because the water will immediately drain.
Good luck.
m
