SOURCE: 1997 buick lasabre custom high idle, transmission, stalling
had same problem i would check the Idel Air Valve and also check all of your vaccum hose lines makeing sure there are no cracks or splits in rubber connectors if there is repair immediatelt because over time they start to dammage the internal parts fo the engine and if youve replace tps mass air etc. sounds like a vaccum hose problem
SOURCE: how do i remove the rear passanger 2000buick lasabre door panel.
You'll need to remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. If needed, you can pull back the weather seal (can't reuse it, but it's not that important) and you will be able to access everything inside the door
SOURCE: oil sending unit on buick lasabre 2000 is leaking .
Passenger side wheel well. Screwed in the block above the passenger side cv shaft below the power steering pump.
SOURCE: how to remove transmission from a 2000 Buick
jack the car as high as you can, then remove the driver side suspension and tie the brake caliper out of the way, remove the coolines and connectors and linkage from top and sides of trans, put a transmission jack (u can rent these) under the pan of the trans and loosen the trans mounts, then jack the trans up and pull it out, this is a bugger of a job with a lift so good luck
SOURCE: DASHBOARD PROBLEM WITH GAUGES NOT WORKING. 2000 BUICK LASABRE
your gauges need to be replaced it sounds like you have a bad mother board on it.
