Question about Vehicle Parts & Accessories
Spark plug wiring diagram for a 2003 chevy malibu
Need diagram for spark wiring
e_a_stocker
    Problem Solver:
  • 6 Answers
SPARK PLUG WIRE REPLACEMENT (ENGINE CONTROLS - 3.1L)
Removal Procedure
  1. Turn OFF the ignition.
  2. Notice: Twist the spark plug boot one-half turn in order to release the boot. Pull on the spark plug boot only. Do not pull on the spark plug wire or the wire could be damaged.
  3. Remove the spark plug wires 2, 4, and 6 from the engine left side spark plugs.
  4. Remove the spark plug wires from the retaining clips.
  5. Remove the spark plug wires 1, 3, and 5 from the engine right side spark plugs.
  6. Remove the spark plug wires from the retaining clip.
  8. Remove the spark plug wires from the ignition coils.
  9. Remove the spark plug wires from the engine.
  10. If you are replacing the spark plug wires, transfer any of the following components:
    • Spark plug wire conduit
    • Spark plug wire retaining clips
Installation Procedure
  1. Install the spark plug wires to the engine.
  2. Install the spark plug wires to the ignition coils.
  4. Install the spark plug wires 1, 3, and 5 to the engine right side spark plugs.
  5. Install the spark plug wires to the retaining clip.
  7. Install the spark plug wires 2, 4, and 6 to the engine left side spark plugs.
  8. Install the spark plug wires to the retaining clips.
v\:* { behavior : url(#default#VML); position:absolute; } v\:* { behavior : url(#default#VML); position:absolute; }
Posted on Aug 20, 2014
Spark plug gap for 2003 chevy malibu l 3.1 liter
Your owners manual shows .060 spark plug gap.
Different spark plug manufacturers may list different gap specs.
If you don't have an owners manual you can read it online.
my.gm.com
Dec 14, 2016 | 2003 Chevrolet Malibu
How do i change the spark plugs in a 2003 chevy malibu?
On this model it has a 3.1 liter v-6 the coil pack is near the firewall and coil pairing (firing order) 1-4,2-5,3-6 the front cylinders are the easy to replace that 2,4,6 and the rears are 1,3,5 starting from the fan belt . suggest using your phone to take several pictures so you do not get the wires mixed up. most of the wires have a metal housing surrounding the plug boot this is to be installed on the new wires. as engines heat up and cool down this wires are like welded to the spark plug. so pulling and twisting the ends is normal (of coarse swearing is involved also) After replacing the spark plugs remember to put a silicone grease inside the spark plug boot for easier removal next time you decide to change the spark plugs
Jul 23, 2014 | 2003 Chevrolet Malibu
How do i know when my spark plugs and wires are bad
have to take one by one together out and start a car .or with the proper totool
Sep 03, 2012 | 2003 Chevrolet Malibu
Spark plug wires diagram 03 impala
For complete spark plug detail for chevy impala car model.Click the link below :-------http://technoanswers.blogspot.in/2012/02/spark-plug-replacing-for-chevy-impala.html
-------Thanks.
Jan 30, 2012 | 2003 Chevrolet Impala
99 chevy malibu fuel mileage going down. Use to
check you mileage if the car has over 100,000 miles and you have not had a tune up it maybe time for spark plugs, air filter,fuel filter and spark plug wires if needed
Dec 17, 2009 | 1999 Chevrolet Malibu
I need the diagram to put the spark plug cables
2003 Chevrolet Malibu 3.1L SFI OHV 6cyl
Spark Plug Wires - Removal & Installation
3.5L Engine
  1. Before servicing the vehicle, refer to the Precautions Section.
    NOTE Twist the spark plug boot one-half turn in order to release the boot. Pull on the spark plug boot only. Do not pull on the spark plug wire or the wire could be damaged.
  2. Remove the intake manifold cover, if required.
  3. Disconnect the left side spark plug wires from the spark plugs.
  4. Disconnect the left side spark plug wires from the ignition coil.
  5. Remove the spark plug wire clips from the Manifold Absolute Pressure (MAP) sensor bracket and the heater inlet and outlet pipe tab.
  6. Remove the spark plug wire assembly.
  7. If replacing only one plug wire, open the retaining clips and remove the appropriate spark plug wire.
  8. Disconnect the right side spark plug wires from the spark plugs.
  9. Disconnect the right side spark plugs from the ignition coils.
  10. Remove the spark plug wire assembly.
  11. If replacing only one plug wire, open the retaining clip and remove the appropriate spark plug wire.
To install:
  1. Install the spark plug wire assembly.
  2. Connect the right side spark plugs to the ignition coils.
  3. Connect the right side spark plug wires to the spark plugs.
  4. If replacing only one plug wire, open the retaining clip and install the appropriate spark plug wire.
  5. Install the spark plug wire assembly.
  6. Connect the left side spark plug wires to the spark plugs.
  7. Connect the left side spark plug wires to the ignition coil.
  8. Install the spark plug wire clips to the MAP sensor bracket and the heater inlet and outlet pipe tab.
  9. If replacing only one plug wire, open the retaining clips and install the appropriate spark plug wire.
  10. Install the intake manifold cover, if required.
Fig. 2.2L Engine Firing Order: 1-3-4-2 Distributorless ignition system
Fig. 3.1L Engine Firing order: 1-2-3-4-5-6 Distributorless ignition system
Fig. 3.5L Engine Firing order: 1-2-3-4-5-6 Distributorless ignition system
Fig. 2.4L Engine Firing order: 1-3-4-2 Distributorless ignition system
Fig. 3.5L & 3.9L Engines Firing order: 1-2-3-4-5-6 Distributorless ignition system
I really hope help you with this (remember rated this help) Good luck.
Sep 23, 2009 | 2003 Chevrolet Malibu
What is the wiring order from the distributor to the spark plugs on a chevy malibu 2003
Do you mean from the coil packs? 2003 malibu has no distributor. What engine do you have?
Jul 08, 2009 | 2003 Chevrolet Malibu
2003 chevy malibu wont start
If you have spark, and fuel , and still no start, I'd first pull out the spark plugs and make sure they are not fuel fouled. Dry or replace as necessary. Do you have compression ?
Apr 11, 2009 | 2003 Chevrolet Malibu
My 2003 chevy malibu
No if it was the fuel pump it would not run at all.
Aug 22, 2008 | 2003 Chevrolet Malibu
Vehicle Parts & Accessories Logo
557 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Lawrence Oravetz
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
