Question about Ultra Products Zmodo 4ch Ultra High Res Cctv Security System 500gb Ir
Why does my zmodo dvr alarm going off - Ultra Products Zmodo 4ch Ultra High Res Cctv Security System 500gb Ir
David Schneider
    New Friend:
  • 33 Answers
Check the log it could be multiple items causing this problem. Could be over heating, bad hard drive fan failure.
Posted on Sep 10, 2014
Why did video from zmodo san8 stop working on tv after reboot? Screen is only black now
Zmodo has some of the best Customer Service of any company. I have one of their DVR and camera set-ups, and every question I ever had*** was answered over the phone immediately.
(I am not a "schill", nor do I have a financial interest in them other than purchasing their products: I actually own a bunch of their cameras and a DVR unit)
I would recommend simply giving them a call, they will likely answer your questions quickly, thoroughly, and completely.
(at least that was my experience!)
US Office: 17870 Castleton Street, Suite 200, City of Industry, CA 91748
Toll Free: 866-551-6881
Telephone: 217-903-5674
Telephone Service Hours: Mon-Fri 8:00am-8:00pm CST
*** I must say that some parts of their Instructions / User Manual are very concise, self-explanatory, and easy to understand, if one has an IQ of 160+ !!! But the phone support is tremendous..
Jul 27, 2014 | OEM Systems Zmodo Surveillance...
Why zmodo cameras lost color
Make sure you have the DVR set to NTSC instead of PAL first. If it is correct then your camera is defective.
Jul 04, 2014 | OEM Systems Zmodo Surveillance...
MENU DISPLAY FAILS
thanks I pulled out its battery and tried to reboot for factory setting, but that also failed. now it is just running but without any result.
Mar 15, 2014 | OEM Systems Zmodo Surveillance...
No video with zmodo DVR-H9118V
I am having the same problem with a zmodo san8, did you ever find an answer?
Dec 08, 2013 | Zmodo 8 Channel Cctv Security Surveillance...
How to hook up audio
Connect a microphone and enable the audio. It should all be in the settings. Check each camera to make sure audio is enabled. Usually it is off by default.
Jun 24, 2013 | Zmodo dvr-dk41103-1tb cctv 4 ch home...
Alarm chirping
have to turn off all your alarm settings and motion settings to stop the chirp. the chirp is the motion alarm.
Mar 30, 2013 | Zmodo 8 Channel H.264 Surveillance...
Zmoda "no root"
You will need to contact Zmodo. It is most likely a corrupt password. You maybe able to access your menu, but wont be able to do anything and will get the "no root" error message. They will verify you are the actual owner via either your registration or a number off your orig invoice, for security reasons. (You could be a crook trying to delete the evidence, its good they check) They will then give you a bypass admin code to put in, then direct you to change your password and you should be all set. I just got done doing this after waiting for an hr with their online LIVE chat, and finally just called and waited the 15 mins for someone to answer. Its a small shop, but, they were friendly, knowledgeable and most important, spoke REAL ENGLISH!! =]) I spoke with Tony and after I got it fixed, he gave me a case number which will allow me not to have to go through all the verification next time around if I give it to him.. so, find your invoice and place that case number on it for future reference and put it in a handy location you wont forget.
Hope this helps the 20 plus ppl I found also asking pretty much the same question. I looked all over the net and I am an IT Professional and I couldn't find an answer.. even on their website. I plan on adding the answer there too as well. Have a GREAT DAY! =])
Jan 08, 2013 | OEM Systems Zmodo Surveillance...
When i reboot my Zmodo dvr I Can't get menu to come up or mouse to work HDD light keeps flashing,blinking hdd light,HDD indicator light
I had the same problem. Did their online tech support and Patty told me to hold down the "rewind" button on the DVR for 20 secs. You should now be able to right click your mouse to access the on screen menu. You will now want to go under system, and a/v setup and change the device to VGA instead of Vout. Now you can reboot and not have to go thru holding down the buttons anymore. Worked for me.
Oct 02, 2012 | ECHO1USA Zmodo 4 Ch Complete Dvr Kit -...
Zmodo blinking hdd light
A blinking HDD light means it is reading/writing; under normal conditions anyway. Just means that it's being accessed, that's all.
Now if your TV screen is also BLANK, then you have the same problem I do... I'm just waiting on a reply. Mine is the Zmodo ZMD-DX-SBN8 but should be similar enough, I think.
Jan 18, 2012 | OEM Systems Zmodo Surveillance...
Ultra Products Zmodo 4ch Ultra High Res Cctv Security System 500gb Ir Logo
274 people viewed this question
Top Ultra Products Home Security Experts
Marvin
Marvin
Tom Chichester
Are you an Ultra Products Home Security Expert? Answer questions, earn points and help others
