You can use the EDATE function to quickly add or subtract months from a date. The EDATE function requires two arguments: the start date and the number of months that you want to add or subtract. To subtract months, enter a negative number as the second argument. For example, =EDATE("9/15/19",-5) returns 4/15/19.
You have to start the sequence with a slightly different formula because there is no preceding value for Monday.
The rest of the formulas are running totals so they are the same just dynamically duplicated down the column add infinitum.
Just duplicate the the formula Picking up the value form the result column and subtracting the next running subtraction value.
Step1. Start Microsoft Excel and open the file you want to change.
Step2. Double-click on the cell where you want the total to appear.
Step3. Press the = key on the keyboard. This tells Excel that you are entering a formula into the cell.
Step4. Enter the formula, then press Enter. Follow the steps below for an example.
Step5. Enter an opening parenthesis character: (.
Step6. Enter a cell name. For example: =(E2.
Step7. Press the + key.
Step8. Enter another cell name and a closing parenthesis character: ). For example: =(E2+E3).
Step9. Enter a minus sign and a third cell name. For example: =(E2+E3)-E4.
Step10. Press the Enter key to accept the formula. The cell will display the sum of the first two cells minus the third cell.
$('.Article .Steps .Image').each(function(i,e){
e = $(e);
e.find('img').error(function(){
$(this).unbind();
e.remove();
Tips & Warnings
Formulas are just equations. Instead of adding or subtracting numbers you are adding and subtracting the contents of a cell.
Excel
includes a number of predefined functions to use as well. You can
combine the predefined functions into your own formula. (See "How to
Use Provided Excel Formulas.")
Any formula in Excel starts with the equals sign ("="). This is how Excel distinguishes between formulas and literal values. Knowing this, you can create lots of formulas using the usual operators of +, -, * and / for addition, subtraction, multiplication and division, respectively. Please see the examples below.
Add 1 + 1: =1+1
Add the contents of cell A1 to the contents of cell B1: =A1+B1
Subtract 2 - 1: =2-1
Add the contents of cell A1 from the contents of cell B1: =B1-A1
Multiply 1 times 2: =1*2
Multiply the contents of cell A1 times the contents of cell B1: =A1*B1
I hope this resolves the question. If not, please let me know.
