Question about Hoisting
Tent trailer I have a 1980 Bonair tent trailer with built in jacks and I need help with putting them back up
Rob Fairley
    New Friend:
First of all clean the jacks very thoroughly. If they are really dirty, tap gently with a hammer to release sand and dirt, hose thoroughly, repeat. Lubricate every part of the jack with lots of wd40. Check that the part of the jack that extends down has been fully released and pushed up into the upper portion of the jack. Then grasp the jack with both hands and tug it down. While the jack is pulled down, swing it up under the trailer until it clicks into place.
Posted on Jul 30, 2015
1978 bonair tent trailer has a 110 plus 12 volt system but wires were cut from coverter. I would like a drawing of how to reconnect wiring system
Building their first recreational trailers in 1983, Bonair offered a wide range of small to medium-sized products. Bonair concluded production of recreational vehicles after the 1999 model year.
It will be difficult to find manuals for legacy RVs. Try an online enthusiast forum.
Jun 24, 2016 | RVs
I have a Bonair 600 tent trailer furnace will not start with new battery but will work if pluged in
Check fuse, check 12 volt wiring, may have to replace board. Look close connections may be corroded.
Aug 25, 2014 | Heating & Cooling
Trigano cheverny tent
Untie the cover and pull it back. Then unfold the camper trailer either sideways or backwards. Anchor with pegs, add poles and ropes as necessary. If you have specific models in mind, there is often a youtube video on the model that you're working with.
May 19, 2014 | Camping, Backpacking & Hiking
Bent tent trailer rails for pop out beds, how do we fix
Try bending rails back into shape or make new (stronger) ones. I have shared your experience. Set up trailer in rain, jumped into bed, and supports fell out! Also set up tent in the dark in the rain after one quick lesson and no instructions.
Nov 18, 2011 | Sport & Outdoor - Others
We have a Rockwood Signature ultralite travel trailer 8315bss and we would like to know why it is that we cant level the back of the trailer with the power jacks it seems like the left side is down and...
There is a certain amount of flex in the frame, but it is also possible you using the levels wrong. Are they built in, or are you attaching them as needed?
I would get a 4' level and put it in the middle of the floor.
Built in levels bubbles rarely work well because they are not long enough.
Level front to back first, and then side to side.
Jun 25, 2011 | Dodge Ram 1500 Cars & Trucks
I have a Centurion power converter 30 amp for a bonair tent trailer.I have power to my plug outlets when i am plugged into household power but no dome lights which i assume are 12 volt.Would this mean the...
the converter might not be working and is letting in too many volts and over powering it to the point of not working var fctb_tool=null; function FCTB_Init_18d1597bc4e042ef83fc9da550d91841(t) { fctb_tool=t; start(fctb_tool); } FCTB_Init_18d1597bc4e042ef83fc9da550d91841(document['FCTB_Init_2f479b557e0942269c917ba4c26f8cca']); delete document['FCTB_Init_2f479b557e0942269c917ba4c26f8cca'] var fctb_tool=null; function FCTB_Init_6055a1a4f8f0424782d2160b7b182f51(t) { fctb_tool=t; start(fctb_tool); } FCTB_Init_6055a1a4f8f0424782d2160b7b182f51(document['FCTB_Init_ad434a04dea2406ca738d57fb96fd227']); delete document['FCTB_Init_ad434a04dea2406ca738d57fb96fd227']
May 05, 2011 | Sport & Outdoor - Others
Interior lights, appliances work fine when plugged
Check for a faulty inline fuse or circuit breaker at harness attached at front of trailer. Follow positive wire back to trailer.
Jul 11, 2010 | Coleman 10' X 10' Sundome Tent 9160K101
Manual for 1982 Coleman Niagara Tent trailer
One is available for download from http://www.popupportal.com/manuals/Coleman/Coleman_1982.pdf
Jul 02, 2009 | Coleman Sport & Outdoor - Others
No brake lights
tey the fuses , check the bulbs
Jul 27, 2008 | 2001 Chrysler PT Cruiser
Hoisting Logo
1,559 people viewed this question
Top Hoisting Experts
AZBen
AZBen
Andrew Taylor
Andrew Taylor
gbob59
Are you a Hoisting Expert? Answer questions, earn points and help others
