Question about Kenmore 98702 Stacked Washer/Dryer
Manual for Kenmore Stacked washer dryer model # 93901
Think Crucial
    Master:
  • Kenmore Master
  • 894 Answers
Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Kenmore model by clicking the link below.
Kenmore 93901 Series Use And Care Manual
You can purchase a wide variety of high quality appliances replacement parts direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/appliances
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Posted on Apr 27, 2018
5 Related Answers
docjohn174
john gagnon
  • 943 Answers
SOURCE: kenmore stacked washer / dryer 2002
hi thanks for the question so your saying your tub is full of water ,did it stop in the middle of the wash cycle or at the end of the wash if its at the end of wash and it doesn, drain then you have a lid switch problem . if thats the case reset your timer as if you want to start a new wash load if it starts to wash your timer is ok replace the lid switch
Posted on Sep 15, 2008
Anonymous
SOURCE: Kenmore Stacked Washer / Dryer Model Number 417.97802792
can the rear bearing on the drier be oiled/greased though the back casing, any easy way of stopping sqeek!
Posted on Oct 14, 2008
Anonymous
SOURCE: Dryer won't spin on my kenmore stacked model 417.90812991
This is the 2nd time I have this problem.
IF you look thry the drum to the back you should see 3 screw heads. Mine has one screw still in the hole and 2 empty holes.
This requires the drum to be removed (like take the drier apart). Behind the drum is Asmbly-shaft (ball hitch) (item 32 in the parts list). This what the 3 screws screw into.
I spent 2 days trying to put the screws in without removing the drum not possible (no way to hold the drum in place)
The first time I had to replace the drum because it wore the rim through.
I have to get 3 new screws and some thread locker.
I recommend that you check the screws every month, Use a long phillips screw drive
Posted on Mar 05, 2009
Anonymous
  • 89 Answers
SOURCE: Kenmore Washer/Dryer Stack -- Need to replace Washer
first of all. comming from a Sears Technician.. (don't yell) -- the delivery drivers only know about delivering stuff. they dont know too much,
if the two are the same size they can be stacked.
sometimes have to rig something up
and yes, for that model the top is removed, clips go on the rear and screwed at the front.
in some areas it is sold seperatly as a stacking kit
Posted on May 28, 2009
Anonymous
  • 107 Answers
SOURCE: My Kenmore 417.94812301 stacked washer/dryer makes
What you need to due is take front off dryer and either you're blower is making the noise, or the idler pulley and even the support wheels could be as well
Posted on Feb 26, 2010
Where is the lint trap on the Kenmore stacked washer dryer model 110.88752794
The lint screen is located on the back wall of the dryer. (Inside of the dryer.)
Here's a link to the owner's manual that may be helpful to download and print out: Kenmore 11088752794 Manual
Aug 26, 2015 | Kenmore Washing Machines
Can stacked washer dryer be separated?
no that's a one peace stacked washer,dryer
Nov 27, 2017 | Kenmore Dryers
On a stacked 417 Kenmore,what is the best way to get to the seal-tub
Here is a service manual for the stacked set. The model may be a little different but the repairs will be the same.
Oct 22, 2012 | Kenmore 98702 Stacked Washer/Dryer
Kenmore stacked washer-dryer 41794802301 dryer wont start
dryer working washer not for a kenmore 41794802301 washer dryer combo
Apr 18, 2010 | Kenmore Dryers
Stacked washer and dryen kenmore looking for pump diagram
Head over to the manufacture's website.
Typically - they have a SUPPORT section that you enter your full model number in, and you can download the manual for free.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 26, 2009 | Kenmore 98702 Stacked Washer/Dryer
Where is the model #on my Kenmore stacked unit?
possible locations
Top- or front-loading washer-dryer combination unit
  • Inside the dryer door, on the door frame
  • On the top of the dryer
  • On the side of the washer, near the bottom, front
  • Under the washer lid
  • Feb 13, 2009 | Kenmore Washing Machines
    Kenmore 98702 Stacked Washer/Dryer Combo Model 417.98702890
    There is an EXTERNAL fuse on the back of the unit.
    Service manual is inside the machine's shell in plastic.
    Jan 06, 2009 | Kenmore 98702 Stacked Washer/Dryer
    Kenmore model 98702
    No - it is one body. it cannot be replaced - only repaired.
    Oct 05, 2008 | Kenmore 98702 Stacked Washer/Dryer
    Dryer door
    I would try to run the dryer again. If that doesn't work, it's time to call the repairman.
    Aug 11, 2008 | Kenmore 98702 Stacked Washer/Dryer
    Kenmore 98702 Stacked Washer/Dryer Logo
    373 people viewed this question
    Michael Thomas
    Michael Thomas
    Paul Carew
    Nicola Conroy
