Question about Pride Health & Beauty
Who fixs batter charger fix ya
Charging light doesent come on to charge
Sam
  • 3,247 Answers
It would be helpful if you provide the model number of your Pride Wheelchair. Also it would help to know which part of the world you live in so that we can direct you to the correct location for service center or dealer who could help.
If the charging light does not come on then it does not necessarily mean the charger is faulty. It could be the battery itself or the power chord or plug could be an issue. There is also sometimes an internal fuse for the charger that could be blown.
In the meantime look at this website to check if your model is listed.
Pride Mobility Products Corp Product Owners Manuals Specification Sheets
Posted on Aug 20, 2014
2 Related Answers
Anonymous
  • 32 Answers
SOURCE: battertys wont charge light on charger is on mains
dead batteries; these batteries drop so low when not in use that wheelchair chargers can not bring them up, sometimesa trickle auto style charger can bring them up
Posted on Apr 20, 2009
Anonymous
  • 32 Answers
SOURCE: batteries are charged disconnected and used seperate charger thet had 3/4 charge to start with push start button nothing wheels locked but when charger is plugged in controller lights light up showing
it sounds like dead cel in one of the batteries, try having batteries loaded tested.
Posted on Jul 13, 2009
How to fix phone charger wier to battery
Dont know what ya mean by fix it but if its not charging ya need to replace the wire or the battery.check em both first before ya buy new
Jun 14, 2014 | Samsung Cell Phones
Battery charger doesn't charge batteries. Light
Check the output on the adapter also check the voltage on the battery , If there is none then the particular unit needs a check. If the adaptor voltage is good then the battery can be faulty
Jul 11, 2011 | Cameras
Though my Worx WG781 cordless 36V, 19 inch lawn mower came with what appeared to be a fully charged battery according to the battery LED lights , it is suggested that it be put on the charger "over...
Could be.Those batteries leak charge even when not in use.I would let it go for 24-48 hours just to be sure.Unless the batteries or charger becomes very hot.
May 20, 2011 | Worx WG788 19Inch 36 Volt Cordless 3In1...
I have the powershot SD3500IS abd it says i need to change the battery pack what is that and how can i fix it also if i dont have a charer can i charge it with the usb ?
"Change batter pack" means your battery is dead. The camera should have come with a charger in the bok that can plug into the outlet in your wall. It uses a lithium ion battery, so you can't use a regular AA batter charger, for instance. You cannot charge the battery via the usb into your computer.
Nov 06, 2010 | Canon PowerShot SD3500 IS / IXUS 210...
Cannon Powershot A720 Low batter
If your charger tries to charge at a rate which is too low for the capacity of the batteries they may never charge fully. Or if they are the wrong chemstry eg NmH not NiCd they will not charge properly. Try a separate charger for you batteries they place to go is a specialist store for the electronic boffin eg Tandy, Radio Shack.
Sep 07, 2009 | Canon PowerShot A720 IS Digital Camera
Battertys wont charge light on charger is on mains but orange charging light does not light to indicate that batters are charging and has been left uncharge for 4 months
Apr 18, 2009 | Jet 3 Ultra Power Chair
Scooter will not charge
Check the fuses may have a Blown fuse
Check to see if power supply witch charges the scooter is not faulty
Regards; Aaron
Sep 13, 2008 | Pride Sonic 3 Wheel Portable Scooter
Sidekick 3 wont turn on
if the light indicates but its not charging. one other thing you can do is a soft reset.take out your SIM card and batter for 30 seconds then replace the SIM card, and hold on to the R button and at the same time replace your battery, your phone should turn on and restart twice. but it will come on.
Apr 06, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Battery won't charge
clean the contacts of the battrey and the charger.if that does not work replace the charger or the battery.goodluck.
Apr 03, 2007 | kawasaki PVS-10921 Portable DVD Player
Health & Beauty Logo
57 people viewed this question
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
