The TV is plugged in but the red light is not coming on.
SOURCE: Insignia 32" TV turns off after turning on and red light comes on
Hi
I have Philips 42pf9431d/37b and i re hucked up my tv.
It truns on and goes to green and red how can i solve it.
SOURCE: INSIGNIA LCD won't turn on
replace 2 condensers in the power supply with greater voltage ones.original are 1000uf 35volt...use 1000uf 65volt...99cents each
power circuit is made to fail with typical tv industry tactics...the warranty is reflected by the life of their condensors (capacitors) average life is 2000 hours..
easy...huh
if your a smoker...you must clean the button cover as they get stuck on with your stupid tobacco residue. 75% of all LCD tv's that smokers own fail this way...
\tough huh?
TRY TO STOP SMOKING...
SOURCE: No picture, no sound, does light the insignia sign. Why?
In about 90% of the time the power supply is defective if the TV fails to power ON.
I repair these power supplies, if you need further assistance write to [email protected]
SOURCE: My insignia 19 inch flat panel wont power on...
Your TV most likely requires service. You may take the unit to the retailer of service to arrange for repairs. Note: physical damage that may have been caused by the unit tipping over would not be covered under the factory warranty.
