SOURCE: harman kardon
Orastie
Wow, general problem here, but the most near your problem could be, power failure, or the Power adapter is bad, or a energy failure at home, time to buy a new adapter.
Carl
SOURCE: toshiba saltellite with internal harman kardon speakers, no sound
go to this link, and download your updated drivers. the driver you need to download is the realtek audio driver. http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1702315&rpn=PSPBGU&modelFilter=P205-S6277&selCategory=3&selFamily=1073768663&selModel=1702315%7CPSPBGU
SOURCE: Harman kardon HK595
I'm not sure of anywhere online, but I actually have a spare set of the satellite speakers sitting at my house, from a unit I had previously (the sub went out). I can make sure they work and get them to you if you'd like, email me at drkstr (at) gmail (dot) com...
But I have only one spare...
I'm not sure about wherever else you can buy them online. I was actually lookin to buy another set when I stumbled on this thread, but they're kinda hard to find lol. The whole unit used to be $30 for a refurb'd model, but those places are out-of-stock currently.
SOURCE: no sound from my harman kardon speakers from imac
Has a speaker system ever worked on the iMac or is this the first try?
Does its onboard speaker work or is it muted? I'd start with some basic setup procedures.
SOURCE: taking apart harman/kardon subwoofer
turn the sub upsidedown, carefully remove the clear rubber feet (these are a dome fitted over a mushroom top), using the toothed gripper cutout of a pair of pliers (when closed it is the eye shaped opening visible on one side), grip the mushroom firmly but not so hard as to crush the mushroom and gently ease clockwise and anticlockwise (the mushroom is at one end of a clear plug blocking access to the four screws that hold the two parts together.
Be carefull to use the correct size screwdriver so as not to damage the screw heads as they are tight.
On reassembly, you may need to use glue to replace the rubber feet if the mushroom becames damages during removal.
You were able to repair it, how was it solved?e able to repair it, how was it solved?
