Question about Kohler CH25 PA-CH730-0040 Command Gasoline Engine
Kohler wiring diagram
I'm converting my scag command pro engine to a courage pro and need to know which wires convert
Posted by chris plank on
5 Related Answers
Joe Hogan
  • 10865 Answers
SOURCE: wiring schematics
Kohler has an entire technical library on their website. Go to Kohler.com and you will find it. good luck
Posted on Jan 21, 2009
rjivaro
  • 158 Answers
SOURCE: electrical wiring for kohler engine
Perhaps you would enjoy the entire service manual. Here it is: http://www.asberry.net/files/TP-2379.pdf
Posted on Apr 29, 2009
Dwain Pippen
  • 376 Answers
SOURCE: kohler command cv15s starter sping in the opposite direction???
It's more likely you hooked the battery up backwards. That reverses the polarity and will make the starter spin backwards.
Posted on Jun 02, 2009
Anonymous
I have a Ford LGT with a 14 hp Kohler K321AS engine. Go to Kohler.com and download the service manual for the K321 engine. The manual covers all of the K type engines and gives diagrams and details of all the different types of ignition and electrical systems. It is free. JS
Posted on Jun 07, 2009
Sheldon Dedek
  • 909 Answers
SOURCE: not charging battery no power on stator wires?
With engine off, check continuity through the stator winding. you should have continuity both ways if testing before the diode. If testing after the diode, and you still have continuity both ways, then your diode is blown and needs to be replaced. If you don't have continuity through the stator windings, then stator is defective.
Some models have a fuse in the charging circuit, look for that as well and test with a meter, don't assume visually.
Posted on Jun 12, 2010
Have a kohler 27 on scag turf tiger the engine will turnover then the starter begins to click and will not start any suggestions
Check the oil for fuel in it. Oil will be really thin and be over filled. Take out the spark plug and see if excess fuel is pushed out when you crank it. If there is then the fuel shut off solenoid on the bottom of the carburetor is leaking fuel into the engine when it's not running.
Oct 01, 2014 | Kohler Command Pro V-Twin Vertical Engine...
Need to know how to wire koler command voltage regulator
We do not have this wiring diagram. Sorry.
May 14, 2013 | Cars & Trucks
My 23 hp kohler courage engine starts and runs for several seconds and stops. The gas is fresh, new plugs.gas filter. Fuel pump is working.The thing ran fine two weeks ago. Thanks, Mike
it sounds like the jet is dirty in the carburetor. Remove the float bowl and in the center there should be a jet that you can remove and clean. There are small holes on the side of it which you can clean with a thin piece of wire. Clean the center hole also.
Mar 25, 2011 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Electrical wiring for kohler engine
Feb 26, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Kohler CH25 PA-CH730-0040 Command Gasoline Engine Logo
278 people viewed this question
Top Kohler Electrical Supplies Experts
John Trevino
Tim Venetis
jdthefixer
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
