Question about Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor
How to release a disc from laptop button stuck
Button on side to release disc is stuck in
Will Halftowaite
  • 508 Answers
Most cd or dvd in computewrs have a small hole them in the door. You will need a paperclip. Straighten it out insert the paerclip into the hole and push gently but firmly. This will open the door up and allow you to retrieve the disk
Posted on Aug 19, 2014
How do I open the DVD tray on my computer? Is there a key stroke or something?
Take a pin and insert into a small tiny hole on the DVD tray it's gonna pop out
Jan 08, 2018 | Computers & Internet
Movie stuck n apple macbook
Hi
I assume you are saying there is a disc stuck inside your machine?
• Have you tried: using the eject button located upper right on your keyboard? Hold it down for 4-5 seconds.
• dragged the Disc-image to the trash?
• if this fails you can try using the Disc tool located in your Applications folder.
• If all else fails, try restarting the machine while holding down the mouse button. This will eject discs. After the disc is ejected let go of the mouse button and the machine starts normally.
• If even this fails you will have to try manually - the "straighten paper-clip method" There is a mechanical lever at the very side of the hole where you insert the disc that can be used to push the disc out. I would reccomend to check your manual for further instructions on this.
Hope this helps
Feb 06, 2015 | Apple MacBook Mac Notebook
A disc is stuck in my dell laptop
Please provide the model number. Also, assuming you're talking about a CD stuck in the drive. There should be a tiny pin hole on the CD/DVD drive bezel. Unplug laptop and remove battery. Then stick a tiny pin in that hole -- should release the catch that keeps the optical drive bay closed. You can then open the drive and remove the disc.
Nov 08, 2014 | Dell Inspiron Computers & Internet
How do I open my disc draw it is stuck with a disc in it
I have had success by putting the computer on end with the disc
drawer facing upwards. then gently tapping the drawer as you hit the eject release
Nov 05, 2014 | Lenovo IdeaPad U260 Laptop Computer -...
Stuck disc in Macbook pro
CD and DVD drives have a manual release.On the door,look for a small hole.You an usually insert a paper clip in this hole to manually release the latch and open the door.
Jul 31, 2012 | Apple MacBook Pro Laptop Computer with...
Toshiba Satellite L450 Series - no access - black screen - was diagnosed with virus - using recovery disc - appears stuck on
If your model Toshiba laptop has a Restore partition on thehard drive then follow these steps to restore your Toshiba to the Out of theBox condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power buttononce to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the systemrecovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running.Follow the prompts that appear on the screen to set up the laptop's date, timeand language settings.
Feb 24, 2012 | Toshiba Satellite Pro L450 Notebook
Dvd is stuck in my ACER laptop how can I get it out
The Acer 5610 has an emergency eject hole to the right of the eject button on the right side of the computer. Find a paperclip and unfold it (or small allan wrench), push the end of the paper clip into the hole until you feel pressure. Press firmly and the optical disc tray should come slightly out of the machine. Grab and pull the tray out (gently). This should work even without power to the drive on any machine tray optical drive, if the tray mechanism is undamaged.
For a slot-loading optical drive, it's a bit trickier. You can try sliding another object into the slot and using it to pry or lift the stuck disc. The safest option is to use another optical disc or credit card sized item and double-sided sticky tape. Put a piece of the tape on the item and then remove the paper from the other side of the sticky tape. Slide the item into the drive with the sticky tape towards the stuck disc (down for most computers). Once far enough into the drive, lower your item and press the tape firmly onto the stuck disc. Lift up and try to pull the stuck disc up and out of the drive.
I hope this helps.
Oct 26, 2011 | Acer Aspire 5610 Notebook
My PC won't allow me to right click to choose the eject option for a CD. I want to know if there is a way to remove the CD manually.
The DVD drive itself has a small horizontal 'eject' button that you can press to eject the disc.
If the button fails the disc is stuck however the DVD drive will have a small hole near the eject button- about 2mm in diameter. Straighten a paperclip or similar and push into the hole until the disc drive mechanism releases and opens.
Thanks,
Javaftper
Aug 07, 2010 | Dell XPS M1330 Notebook
How do i replace the presario v2000 battery? I cannot take the old battery out.
The cover may have been jammed if the laptop was dropped.
1. Use a stiff letter opener and run it along the edges of the battery cover.
2. Move the mechanical lock switch to open
3. Use the stiff letter opener to pry the battery out.
4. The goop you find is probably dried-up coffee, or some energy drink...
Sep 28, 2009 | HP Compaq Presario V2000 Notebook
Dell Studio 17 Stuck Disc in drive
if you look close infront of the cd-dvd playerdoor there is a little hole if you stick a paper clip in there it will eject it.
Jul 10, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor Logo
46 people viewed this question
Top Intel Computers & Internet Experts
Ekse
Lee Hodgson
Lee Hodgson
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
