Question about Mitsubishi WD Televison & Video
I have a wd-57833 work good I got the same one from some one put in a new lamp tv work for 5 hr then stop working on sound or picture but the lamp is good i put in in my tv and it works so i put the p
I got the TV put in a new lamp the TV work for 5hr and stop the lamp is good, There is power on sound or picture so I tuck the hole unit that has the lamp out of the same TV that is working put it in the one that stopped work and it works just fine, what can be wrong with the TV that stopped if the lamp is good
Posted by James on
Jerry Kramer
  • Mitsubishi Master
  • 3,904 Answers
If the lamp is new and good to go then you may have to reset the lamp replacement counter in your setting menu. When that is set back to zero you wont have a problem until it is time for a new lamp again.
Posted on Aug 23, 2014
5 Related Answers
ladywinn
ladywinn
  • 5138 Answers
SOURCE: Replaced lamp Mitsubishi WD-52531 worked for one day
Ballast Board may be Bad it is what turn Lamp on Call Encompass for parts 1-800-638-3328 or look for one on E-Bay they have good deals on Parts.Also CK Fan to Lamp it maybe defective .Call Mats for Fan 1-800-628-1118 they have lamps also.
Posted on Sep 27, 2009
Anonymous
SOURCE: No picture and no sound after replace lamp for Mitsubishi WD-51525
I was having the same issue after a lamp replacement and the warranty tech said that it was the lamp power supply that went out. The part was on back order and look at the board neaqr the lamp and it had a blown capacitor. This would make since why the lamp would come on then shut off right away. She replaced the capacitor and works fine.
Posted on Jan 02, 2009
Ronnie Houston
  • 2920 Answers
SOURCE: mitsubishi wd 52725 will turn on . did the reset .new lamp.no pow
normally if you change one lamp you have to change them all
Posted on Dec 14, 2008
Anonymous
SOURCE: no picture good sound good lamp can change channel
I have the exact same TV and have had the exact same problem. I talked to a TV repairman who said it has to be my deflection board. I just found this out today so I am looking all over the web for a deflection board. I hope this helps! Tyson
Posted on Oct 07, 2009
techman007
Lavell Turner
  • 1112 Answers
SOURCE: WD-62525, continous amber lamp light. No picture. Lamp is good.
Hello:
Make sure u replace the lamp cover as the safety switch need to be closed to make the set work. If new lamp did not repair your problem , then it may well be the Ballast Board, Sometimes call the Lamp Driver.
Posted on Nov 28, 2009
Mitsubishi wd-65738 flickering
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
May 25, 2017 | Mitsubishi WD-57833 57" HDTV
Mitubishi wd-73738 turns off after 1 min
Weird noise is high pitched or even grinding sound? Sounds like a fan but is not?
Dec 14, 2012 | Mitsubishi WD-57833 57" HDTV
Replaced lamp in my mitsubishi wd 60638 dlp but now I have a flickering picture
Sounds like a new lamp that is generic (not Mitsubishi) as the set does not know which lamp is in the set--works with one and not the other you have found your problem.
May 23, 2012 | Mitsubishi WD-60638 DLP TV
No picture and a loud clicking sound when turn on the tv
I have A sony SXRD 50 inch tv and i am getting sound but no picture
Feb 14, 2011 | Mitsubishi WD-57833 57" HDTV
I have a Mitsubishi WD-57833, made a loud popping noise, piture went out, I removed the bulb it is out, but on the back bottom right side has a sparking goiing on inside, is because the buld went out?...
Yes, its the Lamp sparking is coming from your Ballast Board their is a What they call it Spark Cap diode it will ark when Lamp is Bad. FOX has that Lamp for $139.00 1-800-227-5369 Mats Electronics Listed Lamps for $99.00 and up? 1-800-628-1118
Jan 09, 2010 | Televison & Video
Hello:
Nov 28, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Flickering tv picture
Sounds like something on the main board causing the lamp ro misfire.
Aug 11, 2009 | Mitsubishi WD-57833 57" HDTV
This tv is working when it wants to?
You may have the wrong lamp. The lamp assembly is 915P020A10.
Where do you live?
[email protected]
Mar 07, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Replaced lamp, sound but no picture
Try unplugging the set for 5 minutes and then replug it in, allow 70 seconds for it to boot up (LED stops blinking). See if it works then. If not press the input/device button and menu button at the same time read a 2 digit code (blinking led) flashes first # short pause and the flashes 2nd #. This will be necissary to determine your cause. Most common besides lamp is power supply caps that cause intermittant operation.
Dec 20, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
74 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
