Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Washer help all lights is flashing  and somehow it shows you -oof and inside the machine still I have some clothes and water, please see if you can help me with this problem, machine is less than six months old. thank you.
Posted by Rujino on
Anonymous
    Champion:
  • 249 Answers
It sounds as if its not pumping out ,but it still under warranty???
Posted on Nov 28, 2007
My kenmore washer machine somehow it's just not ding the last spin to dry up the clothes and it's show this code ( F-21)
check to see if water is draining away,and or the outlet hose is ok..and the filter is clean.if there all ok and you still have the sane problem,please get back to me,thankyou
Dec 24, 2012 | Washing Machines
Error message - PE.... on lg intello washer. my washer is full of clothes and water.it won`t get to the cycle for rinsing .I press on auto-off , then start-pause . the light for water-level does not go on...
Is there a lot of water inside like more than normal? That is a pressure sensor error. Check pressure hose inside the washer. It is a small hose about 5/16" diameter connected to the tub and pressure switch. If there's a hole in it the air scape and the pressure switch will not turn off the water. The control board detects the problem and stop will show error code.
Nov 21, 2017 | Washing Machines
Doesn 't spin
Hi just read your posting.Just a couple of questions.Does your machine drain the water out?Does the machine beep and show an error code in lights?Please reply with additional information and I am sure I can help you rectify this fault.
Jul 20, 2010 | Fisher and Paykel GWL11 Top Load Washer
Duet GHW9150P Front Load Washer: F35 keeps flashing clothes are wet, when I turn of...
Check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
May 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Can''t get my clothes out... water still inside
does it have a dial that you can manually turn to start the next cycle? You can usually drain the water by pulling the drain hose out from the wall drain behind hte washer....( usually just shoved in the drain not attached) but be aware that when you hold the hose below the water level in your washer it will start to drain. Then perhaps the door will unlatch.
Sep 09, 2009 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool Duet Sport not running it makes clicks and it grinds
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth.=======
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Dec 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Noise when spinning fast
Dec 15, 2008 | Hotpoint WMA44 Front Load Washer
Makes scratching noise
Nov 19, 2008 | Maytag PAV2300 Top Load Washer
Bosch exxcel 1400 express
unplug the device from the mains for few minutes then check out many a times it clears the fault.
Apr 21, 2008 | Hotpoint WMA44 Front Load Washer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
48 people viewed this question
Top Hotpoint Washing Machines Experts
gbob59
Eric Taylor
Richard C Cohen
Richard C Cohen
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
