Question about Canon PIXMA MP495 InkJet Printer
Canon pixma mp499 is offline how do I fix it?
Need to get it online...don't know how
robertjm123
    Problem Solver:
  • 17 Answers
Make sure that it's powered on. If it is, then it sounds like it's not on your network. Run the setup program and enter your wifi network information into it, so that it gets on your network. If you've already done that, try power cycling the printer. I have to do that with my HP wifi printer every once in a while. When it goes to sleep it drops the connection.
Posted on Aug 20, 2014
lucynelson
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 7 Answers
Here are few steps to solve Canon pixma mp499 offline issue:
  1. First of all, you have to turn off your printer.
  2. Second step is to wait for a minute and then again turn on the printer.
  3. Then reconnect your printer with the wifi. Whenever a canon printer won't connect to wifi, the printer shows the offline issue. So make sure your wifi is properly connected with the printer.
  4. Now click on the disable "Use Printer Offline" Option from the system.
  5. Now go for the restart printer spooler option.
  6. Now check whether your printer driver is updated or not. If not, then update it now.
Hope these steps will help you to solve printer offline issue.
Posted on Sep 23, 2021
Erica turner
    Novelist:
    Habit-Forming:
  • Canon Expert
  • 76 Answers
  1. Plugin the Canon printer and press the on button. If you need an ethernet connection for your Canon printer to access the Internet, take an ethernet cable and plug one end into the printer and one end into the router.
  2. If you have a Canon printer installation CD, plug it into your operating system and allow you to run the installation software. You will obey some on-screen instructions after inserting the installation CD.
  3. You need to search the manual of instructions that came with your printer to connect your printer design to the internet. If you do not have an instruction manual, open the website of Canon, click Help, select Manuals, click Printer, then pick your printer model number.
  4. Confirm that your machine and Canon printer are on the same network to allow your printer to respond appropriately to commands.
I hope this answer helps you all.Setup Canon Pixma MP495 Printer to WiFi
Posted on Oct 18, 2019
5 Related Answers
Anonymous
  • 269 Answers
SOURCE: Where is Canon Pixma 190 serial number ?
here is the image where you find the serial number for your Canon Pixma 190 printer
This will help. Thanks please keep updated. please do rate the solution positively .Thank you for using Fixya
Regards
manish
Posted on Mar 23, 2010
Battu Sarath
  • 181 Answers
SOURCE: computer wont recognize my canon pixma 830
Download printer software
open google home page search driver magician
insatl update
all drivers
serch driver version size relaze dete
try
ad coment next solution send
Posted on Oct 30, 2010
Anonymous
  • 78 Answers
SOURCE: I keep getting message that my Canon Printer Pixma
Here's the steps in order for you to get your printer ONLINE and be able to print.
1. Click on your START menu
2. SETTINGS / Printers and FAXES or via COTNROL PANEL, printers and faxes
3. RIGHT click on your printer
4. Make sure "Use Printer Offline" is NOT ticked, if it is, UNtick it
Your printer should respond immediately if there are documents on queue for printing and should print it out.
Hope this helps!
Good Luck!
Posted on Mar 14, 2011
alpug
Danilo Baraquiel
  • 1961 Answers
SOURCE: I have the canon pixma
I was assuming you are using a windows xp operating system. Here is what you need to do.
Click on Start
Select Printers and Faxes
See if the printer's icon is blurred or clear. If its blurred then, some of the reasons are usb cable not properly fix to both the printer and the usb slot of your computer / printer was set to use as offline / printer is turn off or has no power.
If the printer's icon is blurred, double click it.
A small window will appear, Press the Printer menu and scroll down to "Use Printer Offline"
Make sure it is uncheck.
Close the window and see if the image of the printer's icon become clear.
Good Luck!
Please do rate my answer.
Thanks
Posted on Mar 18, 2011
Geekman
Chris Hingee
  • 32281 Answers
SOURCE: can you help get an online free downloadable printer installer for my Canon PIXMA E510 Inhhkjet Photo All-In-One since i don't have a CD/DVD driver in my notebook? thanx....
You can download the Canon printer drivers from their support WEB site. Please click on this link and select your model printer to download : - http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
Posted on Nov 25, 2012
Canon mp499 not recognizing paper
There's no way to know for sure but you could try using a thicker paper sometimes you think of paper rather than a cheap copy paper will solve your problem also you have to make sure that the paper is pushed in
Prints a test page...but nothing else..says is offline
try on the print menu open file and you will see offline click on it to change to online and let me know again if we can try another solution
1helpful
3answers
Canon PIXMA MP495 InkJet Printer - Offline issues
For Vista wireless setup: Open your Control Panel. Choose Printers. In the Printers box it lists your printers. Hover over the wireless printer icon, right click, choose Run as Administrator, then choose Use Printer online. This should change the status of the printer to Ready (from Offline). Be sure you've chosen this printer as your default printer. Might have to do this on a regular basis.
I have the canon pixma mx 340 getting ready to print and it says offline...i can't get it to go online HELP!!!
Click on Start
Good Luck!
Thanks
2helpful
2answers
Canon Pixma MP150 offline - won't print from computer
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
tokio-25
I was trying to print using a PIXMA iP1300 but it doesn't allow printing withe a message box appearing "printer is offline".can you help me please
Printer offline : make online in printer properties.Printer offline when start to print : head problem. Replace head.
Canon PIXMA MP495 InkJet Printer Logo
old marine
old marine
Ekse
