Question about Frigidaire FER641FS Electric Dryer
What size screw is use to install the dryer cord to the dryer terminal
Electrolux
  • Official Brand Answer
  • 4,342 Answers
Hello friend, thank you for allowing me the opportunity to assist you!
The screws that are used to install the dryer cord to your Frigidaire dryer terminal are stainless 1/4 inch screws. I hope this is helpful. -Matt
Posted on Aug 20, 2014
What type of screws do I need for a Kenmore 80 series dryer power cord (where the three screws hold the wire to the terminal)
They are machine screws. Remove the terminal block and take it to the hardware store to match the size of the "lugs." Terminal Block 5304409888
New 4 pin plug
All domestic dryers have a 3 screw terminal block which you connect the cord to. 3 wire cords connect the outer wires to the outer terminal screws, with the center wire connected to the center terminal block screw. 4 wire cords connect with the red or black to either outer terminal screw, the white connected to the center terminal block screw, and the green to the adjcent cabinet screw usually green in color.
Apr 09, 2014 • Dryers
Need to replace 4 prong cord with a 3 prong cord on a new 500 series dryer.
On the back of the dryer, remove the screw(s) that hold the access cover to the back panel that cover the terminal block where the cord goes through the back panel and connects to the wiring terminal power block, loosen the two screws on the cord clamp the clamp it to the back of the dryer just enough to release the cord, remove the four nuts / screws that are connecting the 4 wires from the cord to the terminal block and or the back of the dryer,with the new 3 wire cord just match the colors on the terminal block with the same color wires that are connected to the other side of the terminal block, red,black on the outer most terminals and the white or green to the middle terminal, IT IS IMPORTANT THAT YOU PLACE A JUMPER WIRE/STRAP FROM THE MIDDLE TERMINAL WHERE THE WHITE OR GREEN WIRE CONNECTS TO THE TERMINAL BLOCK OVER TO THE CASE/CABINET OF THE DRYER, THIS CAN CONNECT TO THE CASE AT ANY AVAILABLE SCREW NEAR THE TERMINAL BLOCK! In short this means that the neutral and ground of the dryer must be connected together in a 3 wire set-up.
GOOD LUCK!
4helpful
2answers
How do you hook the four wire electric cable to the terminal marked L1, L2, L3? the wires are colored red, white, black and green.
To connect power cord:
• Remove the screws from the cover of the
junction box located at the top rear of the dryer.
• Loosen/remove the two screws on the strain
relief clamp and remove from 4-wire supply
cord.
• The strain relief splits into two indentical parts.
• Insert the large flange of both sections into the
hole located on the left side of the junction box
housing. The short flange of both sections and
screws must remain positioned on the external
side of the junction box housing.
• Insert the 4- wire supply cord through both
sections of the strain relief and re-install strain
relief screws, do not fully tighten until electrical
connections are complete.
• Attach the power cord ground conductor (green
wire) to the ground terminal marked with the
ground symbol. Tighten screw until ground
conductor is secure. (See Fig. 7)
• Attach the power cord neutral conductor (white
wire) to the neutral terminal. (marked N)
Tighten screw until neutral conductor is secure.
(See Fig. 7)
• Attach the power cord phase conductor (black
wire) to the phase terminal (marked L3).
Tighten screw until power conductor is secure.
(See Fig. 7)
• Attach the power cord phase conductor (red
wire) to the phase terminal (marked L1).
secure.(See Fig. 7)
• Tighten the screws on the strain relief so that
the power cord cannot be moved.
• Re-install the cover of the junction box and
secure with four screws removed earlier.
• The dryer is now ready to be connected to the
power supply receptacle.
This is from the manual for the Danby DCD5505W. You did not give the model # so I went off of what you listed it under.
Good Luck and please rate 4 thumbs for the free answer.
Changing 220 plugs need discription of positive and negitive to dryer
If you are installing a 3 prong cord , then the 2 outer wires , are the power lines , and the center is the neutral . On the dryer , the center wire connects to the white wire on the terminal block . The 2 outer cord wires . 1 connects to the black wire terminal on the block ( outside terminal ) , and the other outside wire , connects to the red ( outside terminal ) on the block . Its the same if you are installing a 4 wire cord , except the green , connects to the ground screw on the dryer itself .
1helpful
3answers
Have an old maytag dryer and need to replace 3 prong cord with 4 prong. How do we attach color coded wires?
First make dryer is unplugged !!!!!!!!! remove cover near cord entrance to dryer, you will notice 3 terminals. you should also see a green screw close by. there may be a wire or strap connecting center terminal to the green screw or ground. remove wires from terminals and remove strap from center to ground screw. connect new cord in the following order. green wire to green screw or ground, white wire to center terminal, black wire to left terminal, and red wire to right terminal. now you are done put the cover back on. I'm glad you asked this question. this is a very popular question. Your new 4 Prong cord is up to current code. I'm happy to see people updating there appliances to current code and making their homes safer. Thanks
Aug 29, 2009 • Dryers
1helpful
Where to wire the ground when changing a three prong to a four pr
This cover is all different sizes and shapes depending on the manufacturer of the dryer, but it is typically very close to where the cord enters the dryer. The cover is typically held in place with 1 - 4 screws. See image to the right of a Maytag Performa dryer access panel.
04b796a.jpg With the cover open you will see a terminal block with three wires. Black on one end, white in the middle and red on the other end. Use your 3/8′ nutdriver to remove the nuts or a phillips screwdriver to remove the bolts (depending on your dryer) and remove each dryer cord wire from the terminal block. When you remove the nuts or bolts, be careful not to drop them down into your dryer. Now you need to install a bonding jumper from the neutral terminal to the dryer’s frame. The bonding jumper is either a metallic strap (typically copper or copperclad) or a green wire that is connected between your dryer’s neutral (white wire) terminal and the green ground screw connected to your dryer’s frame.
Installing this bonding jumper is an extremely important step when changing from a 4-wire to a 3-wire power cord to prevent electrical shocks when touching anything metallic on your dryer.
If you do not have the original bonding strap, you can make one. You need a short piece of green 10 AWG wire, 2 ring terminals, a pair of wire strippers and a pair of crimpers. Strip both ends of the green 10 AWG wire and crimp one ring terminal onto each end of the wire. Now connect one end of the wire to the neutral (center) terminal and the other end to the dryer’s frame; where your ground is connected now. a9fc1b2.jpg Loosen the screws at the connector and pull the cord out. Now thread your new cord through the connector and tighten down. This only needs to be snug do not over tighten. Sometimes the old connector will work with the new cord and sometimes not. If not, your new cord will include a connector that you may use. To hook up your new 3-wire dryer cord, connect each wire to the dryer’s terminal block. The 2 outer wires are your “hot” wires and the center wire is the neutral. Replace the access panel cover and your new 3-wire dryer cord is installed Before plugging in your new dryer cord, I recommend turning off the breaker to your dryer receptacle. Then plug in your dryer. Now turn the breaker back on. This is not fool proof, but it is a safer way to turn on the power to your dryer if you made a mistake connecting your new dryer cord.
If your dryer is different from the one described above and would like a second opinion on your connections, email a picture of the terminal block to info at ezdiyelectricity dot com. I will post the pictures on this page to help others with the same dryer.
1helpful
Connecting 4-wire recectacle 14-30r dryer power cord. i've removed neutral ground wire from dryer external ground conductor and connected it with neutral white cord wire onto center silver-colored terminal...
doesn't matter both are 110v lines but if you want look up to top screw connections the wires coming to those screws are also colored as long as the red and black are to outside screws dryer will work ok
Aug 07, 2008 • Dryers
1helpful
2answers
Cord Connection
If your dryer cord is flat and gray, then simply attach the two outside wires from the cord to the left and right screws on the terminal block. Connect the center wire of the cord to the center screw of the terminal block. The only important wire is the center wire of the cord goes to the center screw of the terminal. The two outside wires don't matter.
1helpful
How to change a dryer power cord from three wire to a four wire cord?
black to left screw on terminal block red to right screw on terminal block green and white to center screw on terminal block screw
Frigidaire FER641FS Electric Dryer Logo
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Michael Thomas
Michael Thomas
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
