If your Delsey combo lock won't lock, there are a few things you can try to troubleshoot the issue:
Check the battery: Make sure the battery in the lock is not dead. If the battery is low, replace it with a new one.
Check the lock's alignment: Make sure that the lock is properly aligned with the suitcase zipper. Sometimes the lock may be slightly off-center, which can prevent it from locking properly.
Check the lock's mechanism: Make sure that the lock's mechanism is not jammed or damaged. If it is, it may need to be repaired or replaced.
Check the lock's code: Make sure you have entered the correct code for the lock. If you have forgotten the code, you may need to reset the lock or contact the manufacturer for assistance.
Clean the lock: Sometimes dirt and debris can accumulate in the lock mechanism, preventing it from functioning properly. Clean the lock with a soft cloth and mild soap.
Check the suitcase: Make sure the suitcase is not damaged in any way that can prevent the lock from closing properly.
If none of these solutions work, it may be best to contact Delsey customer service for further assistance. They may be able to provide additional troubleshooting steps or may suggest to get the lock serviced.
DR/LCK fuse 25 amp . located in the I/P block
Fuse Block - I/P
In the right front kick panel
Power Door Locks System Components
The power lock system consists of the following components:
• Body control module (BCM)
• Driver door lock cylinder switch
• Front passenger door lock cylinder switch
• Driver door lock switch
• Front passenger door lock switch
• Door lock actuators in each of the doors
• DR LK Fuse 20-amp
Door Lock System Controls
The Power Door Lock System is controlled by the body control module (BCM) and can be activated by any one of the following:
• A door lock switch lock or unlock actuation
• A door lock cylinder switch unlock actuation
• A keyless entry transmitter actuation
• An automatic door lock actuation (Personalization function)
• An automatic door unlock actuation (Personalization function)
Door Lock Operation
When the body control module (BCM) detects a transition of either of the door lock switches to the lock position, it switches the door lock actuator lock control circuit to voltage. Since the lock actuator unlock control circuits are at ground potential within the BCM, the door lock actuator motors transition to the lock position.
Driver Door Unlock Operation
When the body control module (BCM) detects a transition of either of the door lock switches to the unlock position, it switches the driver door lock actuator unlock control circuit to voltage. Since the door lock actuator lock control circuit is at ground potential within the BCM, the left front (LF) door lock actuator motor transitions to the Unlock position.
The driver door lock actuator unlock control circuit is a dedicated control circuit used only for the driver door lock actuator motor. This is done so that the driver door may be unlocked by itself using a keyless entry transmitter or an automatic door unlock function (if programmed).
Passenger Door Unlock Operation
When the body control module (BCM) detects a transition of either of the door lock switches to the unlock position, it switches the door lock actuator unlock control circuits to voltage. Since the door lock actuator lock control circuit is at ground potential within the BCM, the passenger door lock actuator motors transition to the unlock position.
The door lock actuator unlock control circuits are dedicated control circuits used only for the passenger door lock actuator motors. This is done so that the driver door may be unlocked separate from the passenger doors using a keyless entry transmitter or an automatic door unlock function (if programmed).
Boot to your Bios and look in advanced for num lock and disable.
or
go to run in the start menu. typ: regedit.
Go to: HKEY_USERS\.Default\Control Panel\Keyboard Then String value- InitialKeyboardIndicators right click click modify then choose a number below.
Explaination numbers.
0= Truns Off, Num Lock, Caps Lock, Scroll Lock 1= Turns On Caps Lock, 2= Turns ON Num Lock, 3= Turns On Caps Lock, and Num Lock 4= Turns ON Scroll Lock 5= Turns on Caps Lock, and Scroll Lock 6= Turns On Num Lock, and Scroll Lock 7= Turns On Caps Lock, Num Lock, and Scroll Lock
*7465625*638*00000000*00000000#
NEXT ENTER
#7465625*638*00000000#
AND THEN *#7465625# to check the locks....all locks are inactive...these are all the locks...
network lock - inactive
subset lock - inactive
sp lock - inactive
cp lock - inactive
sim lock - inactive
activa lock - inactive
phone lock - inactive
auto network - inactive
auto subset lock - inactive
auto sp lock - inactive
auto cp lock - inactive
auto sim lock - inactive
1- Enter code *7465625*28782# without a sim in the phone 2- Phone will display "Auto Subset Lock: Activated!" 3- Enter code *7465625*28638# without a sim again 3- Phone will display "Auto Network Lock: Activated!" 4- Now insert the sim and enjoy! Phone is Unlocked!
(NOTE: When you change sim to other operator repeat this process to unlock it for that operator also)
I found this in another thread. All credits for the solution to Morfeus of the FuriousTeam!
I myself haven't got a locked Z500 so i cannot try this. But other people confirmed this as working. I'd like to hear more results on this!
I also found a list of service codes. I guess you could use some of them to enter your unlock codes manually(that you read out with WinIMEI).
Check Versions of h/w s/w f/w:
*#1111# S/W Version *#1234# Firmware Version *#2222# H/W Version *#8999*8376263# All Versions Together
Locks: *#7465625# = Check Locks *7465625*638*Code# = Enables Network Lock #7465625*638*Code# = Disables Network Lock *7465625*782*Code# = Enables Subset Lock #7465625*782*Code# = Disables Subset Lock *7465625*77*Code# = Enables SP Lock #7465625*77*Code# = Disables SP Lock *7465625*27*Code# = Enables CP Lock #7465625*27*Code# = Disables CP Lock *7465625*746*Code# = Enables SIM Lock #7465625*746*Code# = Disables SIM Lock *7465625*228# = Activa lock ON #7465625*228# = Activa lock OFF *7465625*28638# = Auto Network Lock ON #7465625*28638# = Auto Network Lock OFF *7465625*28782# = Auto Subset Lock ON #7465625*28782# = Auto Subset Lock OFF *7465625*2877# = Auto SP Lock ON #7465625*2877# = Auto SP Lock OFF *7465625*2827# = Auto CP Lock ON #7465625*2827# = Auto CP Lock OFF *7465625*28746# = Auto SIM Lock ON #7465625*28746# = Auto SIM Lock OFF
