Question about Dell 1720dn Laser Printer
My dell 1720 laser printer has 3 black marks down the right side of the printer
Black marks on right side of paper
5 Related Answers
Anonymous
SOURCE: dell 1710 black marks printing down the sides
if you are technician so you can otherwise call printer service engineer
Posted on Feb 27, 2008
Anonymous
SOURCE: problem printing with Dell 3010cn Laser
Check for damage to the fuser located right were the paper exits. damaged fuser can cause lines
Posted on Feb 10, 2009
Paul schanzer
  • 85 Answers
SOURCE: laser scanner on dell 5110cn laser printer, prints black smudges
replace fuser. How far apart is the ghost image?
Posted on Feb 16, 2009
Anonymous
SOURCE: 1720 Dell Laser printer Photoconductor Problem
I finally figured it out (with Dell Tech Support's help)! When you replace the drum, you MUST reset the counter as well. All you have to do is:
1) Turn off the power using the switch on the back of the printer. Open the front door of the printer.
2) Hold Continue button down, power on the printer, and continue to holding Continue down until the LEDs begin to flash. When the LEDs start to flash, release Continue button. The LEDs will continue flashing until only Error LED will be lit.
3) Close the front door. Continue, Ready/Data, Toner Low and Load Paper LEDs should be lit.
4) Wait till the printer completes the POST process. POST is complete when fan noise and rollers stops. After POST wait for 5 seconds
5) Press Cancel button 4 times slowly until the Toner Low LED is lit. This is the procedure resetting the counter.
6) Press and hold Continue until all LEDs begin to cycle in sequence, then release Continue. Now only the Toner Low LED will be lit.
7) Cycle the power of the printer (turn it off and then back on).
GOOD LUCK, EVERYONE!!!
Posted on Apr 16, 2009
Anonymous
  • 53 Answers
SOURCE: toner mess on one side of paper dell 1720 printer
The transfer roller may have toner on it that is making that mess. Remove the toner and drum, look inside the printer, there is a grey roller towards the back of the printer. Is there toner on the right hand side that corresponds to the print out? If there is, cleaning it may only make it worse. Replacing it would be the best solution. You would want to make sure that the drum is clean after replacing the roller, if it is not ,then it will transfer to this roller once again.
Posted on Jul 03, 2009
I have a HP Photosmart D7160 and it won't print 4 X 6. It has black marks on the wrong side when it comes out, but not picture
Try flipping the paper. Probably you need to resize the image for this size, sounds like it is compressed and squnched together into those black marks. See if you can use a preview function.
Jul 31, 2016 | HP Photosmart D7160 InkJet Printer
Artia 6100 machine showing err out of paper.
hi,
ur machines paper sensing sensor have some problem. did u used the paper with black mark on the side.
remove the paper cover . u can see a black square sensor near the side of thermal printer. clean the sensor with an ear bud. do not use any solutions. then check again.
remember use good quality paper. if the black mark on the side of the paper is not perfect this problem can occur (black mark on the paper is for page count and paper sensing)
ok
Dec 23, 2010 | RTO Quinton Cardiology Atria 6100 Ecg...
Schiller AT-2 Plus, placed new paper in machine and machine keeps stating "out of paper" and will not print unless I hold down the manual print.
Your machine has the wrong paper in it or the paper sensor is not working properly.  There should be a black mark on the top left hand corner of each page.  The correct ekg paper and ekg repair is available from Medical Device Depot.
Feb 15, 2010 | Schiller Welch Allyn Cardiovit At 2...
Black marks
Replace the toner cartridge; this happens periodically, especially with refurbished cartridges. Parts of the cartridge can go bad even though the cartridge itself still has ink in it.
Oct 06, 2009 | Lexmark Optra M410 Laser Printer
Printer is destroying my papers
The problem sounds like it is the FUSER. It is notorious for wrinkling paper and causing black marks. Try replacing that, and you should be fine. It's NOT your paper... just try replacing the Fuser.
Sep 15, 2009 | Office Equipment & Supplies
Drum kits marking up and streaking the paper
You can check with Dell to see if there is a maintenance kit for this printer. I know that there is one for the HP counterpart. You will probably need to replace the fuser, and maybe the pickups and rollers, but as I said I am not sure if Dell has a maintenance kit for these machines.
May 26, 2009 | Dell 3100cn Laser Printer
Black marks along the edge of paper
there is probably ink on the rollers. get some paper and just keep feeding it till the black marks stop. and RECYCLE the paper that you fed. DO NOT throw it out
Apr 13, 2009 | Canon MultiPASS F60 All-In-One InkJet...
Black roller marks on right side of paper
Sounds like you have a bad fuser assembly if the drum unit didn't solve the probelm.
Mar 16, 2009 | Brother HL-5240 Laser Printer
Black line down right side of paper
On the ADF check the twink mark on glass scanning mirror
Oct 15, 2007 | HP LaserJet 3055 All-In-One Printer
Dell 1720dn Laser Printer Logo
242 people viewed this question
Top Dell Office Equipment & Supplies Experts
Richard C Cohen
Richard C Cohen
Marvin
Marvin
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
