Question about Powerware 9120 UPS System
How to fix an overtemp error - Powerware 9120 UPS System
klasspappa
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 65 Answers
Replace the fan ...
Posted on Jan 23, 2015
Workcentre 7242, it was showing 01-333 fault at first but after correction another error 010-319 how can i sort out this error code
Error 010-333 for this machine is "Fuser Center Thermistor Overtemp (Over temperature) or Overheat Error"
Error 010-319 for this machine doesn't seem to exist (Yes - I know you've got it - hence the problem post.)
Error 010-319 for other Workstation models (7655, 7665, 7675, 7755, 7765, 7775) is "Fuser Heat Control problem *NOTE: This code must be cleared from Diagnostic Mode"
As regards fixing this error the Xerox website should be helpful
Feb 16, 2014 | Xerox Office Equipment & Supplies
GETTING A ERROR MESSAGE DEVE HOME SENSOR ERROR. THE SENSORS WERE CLEAN AND ALSO THE FUSER ASSEMBLY WAS CHECK IT. I NEED TO KNOW THE NEXT STEP I SHOULD TAKE
That error means there is a problem in the fuser, could be lamp out, thermistor bad, overtemp sensor tripped, any number of things. You can find a new fuser at www.precisionroller.com
Jan 07, 2010 | Samsung CLX 3160fn All-In-One Printer
I have a red light,it blinks 6 times and a quick 3times.its a philips 42pf9631d . is it something i can fix myself? or can anyone help me who had the same problem?
This is an Error code indicating a problem with the Control Module or power supply. Possibly an overtemp. You NEED your user guide to know what this error code means.
You can download a free maunal online using the key code on the s/n label.
Dec 29, 2009 | Philips 42PF9631D 42 in. Plasma Television
The message "50.2 Fuser Error" has appeared in the window. Despite checking all the paper routes and finding nothing the message will not go away and the printer will not work.
That fuser error says that either the overtemp fuse is burned out, or the lamp is burned out, you most likely need a new fuser for the error to go away.
Dec 22, 2009 | HP LaserJet 2840 Printer
Have message "self-diagnotic automatically restart within 15 minutes" but doesn't
That error happens when the fuser goes out, could have a dead lamp or just an open thermistor or overtemp device. You will need a new fuser to clear the error, check www.precisionroller.com for price and availability.
Dec 20, 2009 | Brother HL-4040CN Laser Printer
I FIND THE ERROR 010-320
That's a fuser overtemp fault, meaning your fuser either has a peice of paper jammed up in the fuser or the thermistor is blown (it acts like a fuse during an overtemp indication). You'll prpbably need to replace the fuser unit if it's not a simple jam.
Aug 20, 2009 | Xerox Office Equipment & Supplies
My au Falcon teperature light comes on about a minute after the engine is started, the temperature gauge shows low temperature, the radiator is not boiling, I have taken the temperature sender unit out of...
The low water level sensor is in the overflow bottle, not the overtemp sensor.
The overtemp sensor will be on the motor somewhere.
To check you have the right sensor- short the sensor to ground and observe the overtemp light operation.
You likely have a faulty over temperature switch sensor.
Jun 06, 2009 | 2006 Ford Taurus
System Error E000
okay lets shed some light on the E000 error code on the D680, D880, IR1300 family ( including the 1310,1330,1370,1630,1670)
The error code E00 is a memory threshold error what it means is your machine has logged 4 of the following errors, E001,E002, or E003. It is a lockout error and the machine cannot be used untill the problem has been repaired or the errors cleared. First lets look at the errors:
E001 fuser overtemp means the fixing assy has exceeded the manufacures maximun temp limits
E002 fuser temp dropout means the fixing assy has cooled below a set point during a copy session
E003 fuser no responce means the fixing assy didnt even attempt to warm up at power on
How to fix, most common problem is bad power setting 4 E002's either brown outs of brief power failures.
To clear the error, Enter service mode by pressing additional functions then the # button, use the left or right arrow buttons to scroll to #7 printer press set. again use the arow buttons to scroll to #4 printer reset press set.press the approprite arrow key under the YES to clear the error. unplg the copier and reboot. At this time normal function should return if not and it resets a E00 the nyou can assume either the fixing asy is bad or either the power supply PCB or DC controller is bad and it is getting E001,E003 errors. At that point id call a qualified tech to reserch the problem to avoid spending money on excess parts
Jun 05, 2008 | Office Equipment & Supplies
Error code E00003-0000
The film (plastic) film is probably torn from a piece of paper that got jammed between the upper and lower section causing an overtemp lockout condition.
1. Remove left paper door.
2. Remove conector rear plastic(black) and fuser shields(2) screws holding fuser cover shield and unplug (3)connectors,2on the rear and a small one on the front lower right of fuser unit
3. Remove (2) assemlbly mounting screws one at rear and one
on the front sides.
4. remove unit and purchase new complete unit from cannon
5.Installed new fuser by reversing above steps.
May 28, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Hp 4250 error code 50.3
FALSE FUSER OVERTEMP INDICATION, POWER SUPPLY THAT DRIVES THE FUSING UNIT. MODEL 8150 DOES THE SAME THING. TRY TO GET A REFUND ON THE FUSER?
Apr 15, 2008 | HP LaserJet 4350 Printer
Powerware 9120 UPS System Logo
94 people viewed this question
Top Powerware Computers & Internet Experts
Gruber Power...
Gruber Power...
Marvin
Marvin
Tom Chichester
Are you a Powerware Computer and Internet Expert? Answer questions, earn points and help others
