SOURCE: canon bjc-80 - no print appears but cartridge & paper move normally
I had this problem too. It turned out there was old dry ink in there clogging up the printerhead and it was fixed after I ran the cleaning programme several times. However I can't for the lifeof me remember how to do that now. I know I found it online but it has since vanished. Maybe check your manual?
SOURCE: Error problem on Canon BJC-80
Try this:
1: Unplug Power Cord
2: Hold POWER and RESUME buttons
3: Plug in Power Cord
4: Release buttons after the printers starts up
5: Hold CARTRIDGE and RESUME
6: Press POWER
7: Release all buttons after the beeps
8: Press CARTRIDGE 16 times
9: Press RESUME
10: Unplug the Power cord
SOURCE: Canon BJC- 1000 LPT
You need to reset the printer, I see if I can find reset procedure for your model
SOURCE: canon BJC 8500 WASTE INK FULL
How to Reset Waste Ink Protection Counter Canon Pixma IP8500 Printer
Instructions:
Resetting Waste Ink Counter Canon Pixma IP6000, Canon MP450, Canon Pixma IP8500
1. Turn off the printer.
2. Whilst pressing Resume button also press on POWER.
3. Then Press RESUME button and release POWER.
4. Then Press RESUME button again .
5. Then release all buttons.
6. Led Indicator should be green and stay green.
7. Click RESUME button 4 times if you wish to try again.
Then See Table Below:
Orange - Service test print ONCE - Orange - Service test print.
Green - EEPROM information TWICE - Green - EEPROM information print.
Orange - EEPROM initialization 3 TIMES - Orange - EEPROM initialization.
Green - Waste ink counter resetting 4 TIMES - Green - Waste ink counter resetting
Orange - Destination setting (Press Power then Press Resume 3x) 5 times - Orange - Destination setting (Press Power Press Resume 3x)
Green - Print head deep cleaning 6 TIMES - Green - Print head deep cleaning.
Orange - Green, Orange - Return to menu selection 11-13 TIMES - Orange, Green, Orange - Return to menu selection.
Green - Left margin correction 14 TIMES - Green - Left margin correction.
8. Turn off printer.
9. Restart Printer.
Good Luck!
Tinteiros - Magic Inkjet Flush (Ebay)
SOURCE: my canon bjc 80 wont print and error light
Indicates Waste Ink Full error
To repair follow the steps below
6: Press POWER
9: Press RESUME
I have had a similar problem to this: I have had a BJC 80 for nearly 5 years and carried it around with my laptop using Win 98 and a par - par cable. It worked beautifully and successfully - so much so that when i saw a number of ink tanks going at very cheap volume prices in PC World i picked up a lot of them. Changing to an XP meant that i had to keep on using the par to par cable via a docking station but prevented my use of it with my new laptop - so when i brought it out of retirement it gave the blank printing problems yoiu described. By checking some error messages that it expected a black cartridge (which is what was installed) i found that inthe setup the software indicated it defaulted to colour cartridges. By changing this on the computer, it still printed blank pages but by changing the cartridge to colour it sprang into life when the set up asked for colour. I tried 2 other print heads which i had (3-4 years old) but still blank paper when printing to a black cartridge. I am now awaiting a new black print head carrier to see if it makes a difference. When trying with my laptop using XP and a par - usb cable it does not work at all. I have removed the sware driver for the Canon 80 and manually installed the one for the Canon 85 but no luck in printing to par - usb at this time
S Ranson
