Changed black ink error code comes up 3807 will not work or accept cartridge
SOURCE: Paper does not feed and E3 error code is flashing
I have one of these printers and have found the problem, crappy enigineering and inferior parts. Looking at the printer from behind, on the left side (where the motor is located) There are two white gears, located at the bottom and behind a larger black gear. One is of medium size and has a spring. The other is smaller and slides into the medium gear. If you can get these two gears back together and in their proper location, then you're set. But, if you're like me and get frustrated easily, DON'T TRY IT! I broke mine :( A repair will cost as much as a cheap printer, so bite the bullet and hit-up your local rite-aid, they have printers that wont bust the bank. Keep your MP 150, after all the scanner/copier will still work without its attached printer.
SOURCE: error code
well I have had the same thing happen.on the left only use 31[photo]; 32; 34....on the right33; 35..left takes black or 31 photo....right color cartridge only
SOURCE: New Canon ink tank not recognized.
Check that the cartridge chip is not soiled or damaged in any way... Give it a quick clean, check that there's no ink anywhere else on the cartridge as there are sensor points that an LED uses to check the cartridge ink levels too.
If none of that works, phone Canon and request a replacement as some cartridges are known to have faulty chips.
SOURCE: Won't accept non-HP cartridge
You ask "Is this a common problem with non-HP cartridges? " It is a possiblity.
Where did you purchase the cartridges from?
This error might be caused by defective printhead or sensors
Are you removing the 2 protective caps from the cartridges?
Read this HP page:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01451117&lc=en&dlc=en&cc=us&lang=en&rule=17507&product=3203059
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: Message: "Ink empty black" --won't reset
SOLUTION
http://welcome.solutions.brother.com/BSC/public/us/ca/en/faq/faq/000000/000300/000036/faq000336_002.html?reg=us〈=en&c=ca∏=mfc210c_all&page=FaqEndPage
http://welcome.solutions.brother.com/BSC/public/us/ca/en/faq/faq/000000/002400/000061/faq002461_000.html?reg=us〈=en&c=ca∏=mfc210c_all&page=FaqEndPage
