Televison & Video Logo
Question about Alba Televison & Video
My alba flat screen tv made a loud popping noise now it will not work at all
5 Related Answers
Anonymous
SOURCE: Flat screen TV Blew and wont work
It will need a service as one or more of the resisters have blown inside it will require a full check. So up to you as the repair maybe quite expencive depending on the labour costs.
Posted on Dec 17, 2008
Anonymous
  • 39 Answers
SOURCE: on one minute then POP loud noise, burning smell
Loud popping and loss of power is common on plasma TVs and is usually either the Y sustain or Z sustain boards or buffers; in these instances the damaged part will be quite evident.
If this is an LCD you might have degraded insulation on one of the pink/blue backlight power leads causing high voltage to 'arc' to the chassis.
The loud bang and smell is actually to your advantage as in these circumstances the damaged part is usually evident. It'll just be a matter of popping the back off and sleuthing around. :)
Posted on May 19, 2009
Anonymous
  • 1077 Answers
SOURCE: 40 inch flat screen..loud pop heard and tv shut
Try leaving the TV unpugged for 30 minutes so the TV can reset itself.
If that doesn't work, most likely the TV has a power supply related problem.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Posted on Jun 29, 2009
maatmartin7
matt martin
  • 1258 Answers
SOURCE: loud pop from tv,now tv will not turn on
You may have two bad capacitors...I think they may be 10 or 16volts at 1000MFs. They will be bulged..replace and see if it will work!
Posted on Jan 10, 2010
toyladi3
Toyosi Sarumi
  • 597 Answers
SOURCE: TV LG Model 50PX1D-UC Flat
The problem is that there is a bad capacitor inside the unit, it is either on the main panel or the power panel. The popping sound you got was due to the fact that the lead on the capacitor was bridging, therefore causing some electrical popping sound.
Run a check on the main panel and the power panel for any bad capacitor and replace it with a new one. That way, your television will be in good condition once again.
Take care and good luck
Posted on Jan 02, 2011
I have a 47' Vizio lcd flat screen tv. So I turned it on and heard a loud pop noise. Now the tv will not turn on and no power seems to be getting to the tv. I believes its the mothboard mothboard.
That loud pop was a surface mounted "cap" capacitor blowing up. Look for a burnt spot on the circuit boards inside the TV cabinet, it will be very small so look carefully. They are called "Caps" for a reason.
Loud popping noise tv
EHT arcing takes place. Never switch the TV on, until this fault has been rectified. Doing so, will make too many other faults to occur. Contact any service technician.
2answers
I have an alba tv 42" flat screen, and suddenly it
depends on model but this is common problem with the cheap flat screens people are buying now
price should be in the mid 100s for part plus labor to install
Loud pop from tv,now tv will not turn on
2answers
Loud popping noise
The 23" CRT set may have a high voltage breakdown in the flyback transformer or focus divider. Take the back off and operate the set in a dark room. Look for anything that has a blue glow around it or sparks flying when the pop occurs. I won't guarantee this will find your problem, but it is definitive if you see these!
I once had a set with these symptoms. I stopped the blue glow and arcing by covering the focus divider with epoxy. It worked for a couple of months before the divider literally broke apart.
Olevia LT27HVX 27 just blue screen
I just had this same problem over the weekend. Is your TV hooked up via HDMI?? Mine was and i've been having problems with the tv image shrinking whenever i turn on the tv, so i would have to change the channel 1 or 2 times for the image to come up normally. On Saturday I went to change the channel and then all of a sudden I hearld this loud pop and when the image came on it was just a sky blue screen, I couldnt see anything, but I could hear the channel. So I disconnected the HDMI and hooked up the tv with component cables I had and now it works fine. I ordered a new HDMI cable just to see if it will work again. If not, i'm calling Olevia.
Top Alba Televison & Video Experts
 Grubhead
Grubhead
NOEL
NOEL
Are you an Alba Televison and Video Expert? Answer questions, earn points and help others
